Thread: Does an inground winter liner keep worms out?
    Jul 2009
    Eden Prairie, MN
    37
    Had a bunch of rain before the liner went in and the worms at night would crawl in the pool. Now, with the liner on, do the worms crawl under the liner and into the pool when it rains? If so, any tips to block the worms? Thanks.
    AGP partially buried, with surrounding deck and flower bed. 12 x 24 oval x 48" deep Celebration by Forum. Steel sides, vinyl liner. Hayward 2 HP sand pump. Flower fountain - works well to cool water up to 10 degrees.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Does an inground winter liner keep worms out?
    Do you mean the cover? Safety covers don't do much to keep worms out. I can't say about standard winter covers. Cold weather will put an end to the worm activity. I usually have a nasty glob of dead worms every spring when I vacuum the first time.
