Thread: Polaris 360 swallows tail
    poolhound's Avatar
    May 2008
    Elgin, SC
    54
    My Polaris 360 has started "swallowing its tail" 2 out of 3 times I run it. It works fine otherwise and would do this only 1 out of 20 times before. I cant think of any changes I have made. Anyone else have a hungry 360?
    24000gal IG, VL, 1.5 HP, Pentair 60/60D Sand 325#, BBB, Stenner45MHP2 (Replaced Liquidator), Dolphin M400
    poolhound's Avatar
    May 2008
    Elgin, SC
    54
    Re: Polaris 360 swallows tail
    Quote Originally Posted by poolhound
    My Polaris 360 has started pulling the sweephose up inside the body "swallowing its tail" 2 out of 3 times I run it. It works fine otherwise and would do this only 1 out of 20 times before. I cant think of any changes I have made. Anyone else have a hungry 360?
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Isn't this an allegory from something out of the book of Revelations (in the bible)?
    I have a Polaris 280 and I'm proud to state that at no time in my presence has it tried to eat its own tail.
    However, there is a fix for this... an adjustment screw at the junction of the tail and the cleaner that can be tightened, restricting the sweeping motion of the tail, so that it should be nearly impossible for the tail to find its way to the underbody venturi jets. Try it!
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Mar 2009
    Charlotte, NC
    539
    Great Polyview, I'll try that.
    Mine too started swallowing more often since the sponge has mostly broken away ( I don’t plan on replacing it unless I can rig a home-made one)
    I lowered the pressure a tad & it swallows a lot less frequently
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by polyvue
    I like to keep my P-280 tail sweeping pretty fast and it has never swallowed its tail. Occasional water spraying out of pool is great entertainment for the puppies BUT that's why I've had to replace several whole P-280s when the dogs "rescue" and then "kill" the poor things. Expensive doggie toy. I've just about gotten the idea into the new puppies that the Polaris hose, vac hoses, Aquabot line, and PoolSkim ARE NOT TOYS. Very close to trusting them unattended now.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by Johnny B
    I make my own. I use green, non metal, furniture refinish pads about 8" X 6", cut in half or thirds length wise, wrapped around where the sponge fits, and secured with a small plastic tie. I'm not sure of the exact dimensions but I think I get three out of each pad. Cheap, Cheap and they last a long time. You can find the larger scrubby pads at just about any hardware store, paint section, usually several to a pack. The pads are probably around 1/8" or a little more in thickness. Also, there is a seller on eBay, who sells the sponges for a great price. I'm testing one now. I can look up his ID if needed.
    I have had several P-280s since they came out (see reason in above post) and I can assure you that, contrary to what many experienced "pool people" will tell you, if you have a plaster pool, the end plastic left unprotected, where the sponge goes, will wear down to the point where it becomes non functional and may even make some marks. Keep those wear rings checked too. Also, I would be afraid of some kind of damage on vinyl pool from exposed hard end, but just guessing here. Personally I like the scrubbing action the tail "sponge" does on my older plaster; seems to make for less wall brushing. I don't plan to ever have algae, but with my newly-balanced-water-for-the-first-time in, ........ well I can't count back that much, some of the chalking is releasing from surfaces. Thank You TFP (I expect to see more of this when I do the AA treatment in a few days.)
    My finish is old blue plaster, 13 yrs, (Those guys did a fabulous job; wish I could remember who they were.) still in great shape, but very CURED, so you might want to find a little bit less abrasive pad for other finishes or new plaster.
    gg=alice
