Thread: Proper water collection
    Jul 2007
    Florida
    64
    Not to sound lazy but.. can I fill up a large plastic squirt bottle instead of dunking my entire arm to collect water for each test? Any chance test readings would be off since the sample isn't directly out of the pool?
    22,000 gal in-ground, 3-8ft
    Cartridge filter
    Pebble Tec resurfaced
    Polaris 360
    Re: Proper water collection
    Quote Originally Posted by rimshaker
    from what I understand, water should be tested within minutes directly from the pool, about 18 inches from the surface, and furtherest away from the jets.
    14 x 32 x 6 (ave depth) 20K gallons - IG gunite pool. Challenger 1.5 hp pump and cartridge filter.
    30,421
    Rimshaker,
    Yeah, do it the convenient way. Many leave their test kit at the kitchen table, fill up a container from the pool (go down a foot or so) and then come back inside and perform the tests.
    The key thing is that the water sample shouldn't sit around too long, particuarly for the chlorine test. If you get one sample in a squirt bottle and then test the chlorine first and then go ahead and do everything else you will be fine. Just don't collect the water sample and then wait an hour before doing the tests.
