Thread: Another "Fitting for Vacuum Hose" but Different Question
    Aug 2009
    North Central Texas
    I have a 1 1/2 waste pipe that comes off push/pull valve for filter. I want to use a backwash SlimeBag to put waste water back into pool. Because my filter is now too small for the amount of sand/silt the puppies drag in to pool daily I'm having to backwash at least twice a week. I'm going to be replacing the filter soon for a much bigger one.
    Anyway, on the SlimeBag site they show a picture of a blue, standard vacuum hose (the one that is all one length and not sectional) leading from waste, with a SlimeBag attached to put waste water back into pool. They do not show, though, how they attach the hose to waste pipe. Both of the fittings on the end of my vacuum hose are almost exactly the same diameter as the waste 1 1/2" pipe so I haven't been able to attach it. Is there a secret way of fitting it over the waste pipe, maybe heating the end of hose with a hair dryer or something like that or would I need some kind of fitting? When backwashing the pressure and water flow coming out of waste pipe is immense. When I set up drip systems or repair garden hoses I usually heat up water to just below boiling to soften the hoses. Would that work?
    Thanks, gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Mar 2007
    Coastalish 'down easter'
    Re: Another "Fitting for Vacuum Hose" but Different Question
    While I've never played with one of these, a gentle! heating of the cuff should allow you to connect it - but I'd certainly also use a clamp to insure that the hose doesn't pop off!
    Just my $.02
    Luv& Luk
    tsunami's Avatar
    Sep 2008
    Oceanside, CA
    I'm not sure which fitting you need, but they have fittings and clamps for different applications.
    Here's a link that shows the different Slime Bag products. Scroll to the bottom for the fittings and clamps.
    40 X 26 Free Form Pool with attached 9 X 7 Spa raised 18" with 8 Jets and Spillover, and an Art Rock Waterfall/Grotto with accent rocks, 26,000 gallons
    Intelliflo VF-3050 for Pool, VS-3050 for Spa Jets, VS-3050 for Waterfall/Grotto, Quad DE 80, 400K BTU Mastertemp, Intellitouch i7+3 w/ iS10 10 Function Spa-Side Remote, Intellichlor IC40 Salt Chlorinator, Telephone Remote, 2 Intellibrites for Pool/ 1 for Spa, Solar Panels on 2 story Roof w/ 75% coverage
    Pebble Tec Tropical Breeze Tsunami's Pool Build
