Thread: pool cover sagging
    pool cover sagging
    My cover for my inground pool sags bad in the middle (its a solid cover)even after i pump water off, any tips for helping, ive heard put rafts in pool to help
    24 x48 above ground pool.
    hayward sand filter
    Mar 2007
    Coastalish 'down easter'
    Re: pool cover sagging
    Welcome to TFP!!
    Is it a safety cover? If so, it shouldn't sag (much) and the fix is to tighten the straps that secure the cover.
    If it's not a safety cover, it should rest on the pool surface and you're asking for trouble if you try to keep it suspended above the water!
    Let us know what kind of solid cover it is and how it is secured and we'll tell you what you need to do to keep the pool covered for the winter
    Luv& Luk
