Results 1 to 8 of 8
Thread: Closing my Pool
    Closing my Pool
    New to the Forum...Nice to meet all.
    my question is, I am a current Baquacil user, and i've came to find out it very expensive...I'm fixing to close my pool..Do I need to convert to bleach/chlorine pool from baquacil before I close my pool with bleach/chlorine chemicals....
    sorry if my question has came across to confuse a few of you. But I hope someone can help me figure out if I need to convert before I close with a traditional chemicals instead of baquacil..
    Thanks in advance..
    30,426
    Re: Closing my Pool
    Tell us the state and city in which you live....it may make some difference.
    Re: Closing my Pool
    Clintwood, VA
    30,426
    Re: Closing my Pool
    Pretty chilly up there compared to many spots in the South so I assume you will do a full closing...Draining lines, cover, etc.
    I would be very tempted to do nothing but protect the lines and put the cover on it.
    Whatever happens to the pool between now and Spring will be easily fixed when you convert over to chlorine and it probably will save you quite a bit not having to spend anything on closing now.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Closing my Pool
    Quote Originally Posted by snarebeast
    Welcome to TFP, snarebeast...
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Re: Closing my Pool
    we had planned on draining the pool about 3/4 of the way to save on the water bill next year filling it back up....what would be a good suggestion to keep things from freezing? i know to drain lines..etc..etc. But what chemical is it to keep the remaining water from freezing..?
    Thanks for the Welcome..!!!
    30,426
    Re: Closing my Pool
    It's gonna' freeze in your climate. It's normal. Read about closing your pool up in Pool School.....there's no need to drain that much water.
    polyvue's Avatar
    Aug 2009
    1,215
    Re: Closing my Pool
    As duraleigh suggested, there's no chemical to keep the water in the pool from freezing... at least not during extended periods of sub-32 degree air temperatures. It's the pipes, connections and equipment that warrant some sort of protection over the winter -- the water inside these things can expand, causing damage.
    Not sure if you have an above ground or in-ground pool, but one of the following links will get you started. More help is available here from members if you get stuck or have questions about a specific issue.
    Closing (Winterizing) Your Above Ground Pool
    Closing an In Ground Pool
    __
