Results 1 to 12 of 12
Thread: Liner Wear (Pics)
    Liner Wear (Pics)
    Does this seem like a lot of wear for a liner that is only two years old?
    2003 Marquis Euphoria - 400gal
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Liner Wear (Pics)
    It's more than I would expect to see in a pool that hasn't been 'chemically abused' It looks closer to a 4 - 6 year old liner.
    I'm thinking of pattern fading, any chance there is just some white buildup below the waterline?
    Luv& Luk
    -Ted
    Possibly.. going to try and clean tomorrow.. I think I read a magic eraser can be used?
    30,426
    Is the "wear" you are talking about the lighter portion of the liner.....below what appears to be the original waterline?
    yes
    30,426
    Not good.
    I hope it is a light calcium build-up or some type of scum that is easily removed but it looks more to me like a liner fade from a long-term chemistry imbalance.
    How carefully have you monitored your pool water chemistry since you've had the liner?
    ^^^^^ Very closely.. I have struggled with high pH and TA.. and my CYA has been next to nothing. Calcium in the 220 range.
    It has been tough keeping chemicals balanced condering how often I had to add water all summer due to the crack in my steps.
    Could one of these factors be the culprit?
    other comments?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by jjdurrant
    When you say CYA "next to nothing" - have you monitored the FC-CYA relationship? If you have used high FC levels for extended periods of time, especially if the CYA was low, that could be fading from overshocking.... is that a possibility in your case?
    ^^ I think so.. My water loss was so significant over the summer that is was hard to keep things balanced. Hoping next year will be better.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Use a pool vinyl cleaner that they sell at pool stores, the magic eraser is an abrasive, you may not notice damage on your liner but I've taken the print off older liners with it
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Mar 2007
    4,160
    I'd try the magic eraser in one area and see what happens
    I've got to reiterate that I think the liner is damaged
    Luv& Luk
    -Ted
