Results 1 to 9 of 9
Thread: how to blow the lines
    botanica37's Avatar
    Feb 2009
    Oakton, VA
    65
    I tried with the leaf blower today and with a small Shop-Vac (suction only) and it didn't work - not sure why really. We can't figure out how to jerry-rig our compressor. Can someone explain what is the best way to adapt the compressor and if I need to buy certain things??
    Thanks for any advice.
    free form 40k gal, IG, plaster, Triton II 100C sand filter, Lite 2 heater
    1 1/2 HP Pentair Ultra Flow High Performance pump
    Caretaker in-floor cleaning system
    Jun 2007
    New Jersey
    653
    Re: how to blow the lines
    There are lots of ways. This works for me.
    I have a pressure regulator used for spray painting and I set it to about 20 psi. You can also do this at the compressor if it has a built-in regulator. Full compressor pressure of 90 psi.+ is tough to handle with precision and can blow a pump cover or cause other problems.
    Easiest hookup is to screw a quick-connect nozzle into your filter pump winterizing drain. Nozzles come in 1/4" and 3/8" which are also the most common sizes for drain plugs. If it happens to be larger, you can get a bushing at the hardware store. Just take your drain plug to the auto parts store to get a match. Put a matching female quik-connect on the end of your air hose and attach to the nozzle you put on the pump. You are good to blow! Leave your filter MPV on Recirc. to do the return side, and put it on Closed to do the suction side.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    botanica37's Avatar
    Feb 2009
    Oakton, VA
    65
    OK, I will try that for the skimmer/filter. How do I adapt the compressor to blow the caretaker valves? I think they are about 2 inch in diameter. I stuck the hose from the Shop vac in there, but it didn't blow out anything...
    Jun 2007
    New Jersey
    653
    Quote Originally Posted by botanica37
    I don't know anything about in-floor systems, or how to winterize them. That said, enough bushings screwed together will thread that quik-connect male into ANYTHING with a thread. If it is a hole without a thread, then the rubber stopper part from the correct expansion plug plus a air trigger-type nozzle attachment (put the same type quik-connect on that for convenience) will get the job done. I don't know what the pro's do--there may be special adapters but I already had both of the above.
    Mar 2007
    Coastalish 'down easter'
    4,160
    It's been 15 years, but what we used to do on Caretaker systems is open the cap of the 'octopus' and blow each of the five lines 1 by 1 using an expandable plug with a 'tank valve' on each until the 'bank' of inflooor heads bubbled - and leave the plug in!
    We never had the leaf trapper doohickey, but I've had to deal with a couple of them since then and will gladly tell you what can be done for them, if you have one and will remind me of the pipe sizes.
    Luv& Luk
    -Ted
    Hi Ted,
    I am searching for a why to blow the caretaker lines, this is helpful.
    Should I use a shop vac or compressor? and still need to find those tank valved plugs.
    Ste
    17' x 35' oval in-ground, vinyl liner 8' deep end approx 22K of water in pool, Pool Pilot DIG-220 SWG installed March 2007, Triton TR60 sand filter, Water Ace RSP10 pump 220v/1 Hp installed Mar. 2010
    Be sure to check how powerful your compressor is. Mine is a consumer-grade Craftsman model, and didn't have enough guts to do the returns. Blew the main drain just fine, but took FOREVER to do the returns, since the compressor couldn't keep up with constant demand. I plugged into the pump drain, with a standard 1/2 inch fitting.
    Not using the compressor this year. Picked up the biggest Shop-Vac I could. 7 HP should do the trick, I'm hoping
    Kansas City, MO
    13500 gallon Foxx vinyl sport pool--inground (1988)
    Cristal-Flo sand filter
    Ray-Pak 406A digital
    1.5 HP single speed
    400 gallon Heldor inground spa, octagon
    I will go pick up a Ridgid WD 1670 shop vac from home depot tonight, it has 6.5 HP, hope it is enough.
    There is no easy way to blow it from the pump size? Is is ok to blow from the skimmer through the DE filter, then heater to the returns?
    There is no pypass on my DE filter, it has that push-pull valve.
