Results 1 to 9 of 9
Thread: First time pool closing
    Jul 2009
    NorthEast
    40
    We shocked yesterday, have been running pump for 24 hours at shock level and planned on putting cover on today after draining everthing well.
    BUT... pH is now 8.2+ from 7.8 yesterday-must be from the pump running. Do I NEED to bring this down or can i leave it and will it drift down over winter?
    Everything else is in balance. Was planning on using Polyquat 60 but thinking of only using 28/10 instead.
    Thoughts on all?
    **2009 installed 24'/52" AG Vinyl 25mil Printed Liner, 14,000 gallons
    1hp Pentair/Sta-Rite 150# Sand Filter hard plumbed w/timer, 31.5 GPM pump volume.
    'Lil Shark Automatic Vacuum. Addicted to our TF100 Kit :)
    **1995 installed 440 gallon Softub. Indoor use only. Previously used BaquaSpa. :( Would like to convert spa to BBB in 2017. ANY GUIDANCE WELCOMED!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: First time pool closing
    When FC is higher than 10ppm...the FC will read a false high...if it was in range right before shocking, you should be fine
    30,421
    What is 28/10?
    Jul 2009
    NorthEast
    40
    My question was about if 8.2+ pH was ok to close the pool at or should we lower it...... Not about FC. All our levels were good except when we ran the pump overnight while shocking to prepare to close today the aeration of the water must have drifted our pH up and instead of 7.8 it was over 8.2. Are you saying that the FC would give a false high on the pH?
    But it is a moot point now as we went ahead and said... we'll worry about it next spring. Anyone wanna field whether they thought we did the right thing or not? We also ended up using 11 oz of Polyquat 60 instead of 28/10 algaecide.
    Thanks for any assistance.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by resch
    I think this was understood. Very high FC (from shocking) affects measurement of pH. So, your 8.2+ pH may not actually be 8.2+....
    From the description you provided, it sounds like you'll be alright. I don't know if your pH will come down over the winter. Most people try to lower the pH to a range of 7.2 - 7.6 before the close. Upon depletion of the chlorine over time, you may be close to the upper end of this range.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Jul 2009
    NorthEast
    40
    Thank you! I think I was misunderstanding the answer. I appreciate clarification.
    I tried to find info in pool school but didnt see anything about very high FC making pH read wrong. Good to know. Thanks!
    Looking forward to April We love our pool. Wish we could have done it years ago!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    sorry...it was a TYPO...High FC will cause your PH to read false high
    Thanks Polyvue...I did actualy mistype that high FC will cause FC to read high
    Mar 2007
    Coastalish 'down easter'
    4,160
    Quote Originally Posted by dmanb2b
    Welcome to the wonderful world of 'typos' (and the responses they cause :P )
    Luv& Luk
    -Ted
    Quote Originally Posted by polyvue
    I have been wondering this for a while and have not seen it posted anywhere.
    If a FC level above 10 causes a false high PH reading then is there a best guess chart for PH?
    Pool owners with high CYA levels and that go by the best guess CYA chart may need to have their
    FC above 10 to compensate for the high stabilizer levels. So in these cases how does one really know what
    their PH level is at?
