Results 1 to 7 of 7
Thread: What's raising the pH?
    Jerry's Avatar
    Aug 2009
    New Orleans
    48
    I've using 2-3 cups of bleach a day and my pool water seems okay but the pH creeps up.
    My local Home Depot had no muriatic acid so I ended up buying the HTP brand stuff...my local supermarkets/walmarts don't carry muriatic acid.
    What's the cause of pH rising anyway?
    And why is the p lower case and the H capital?
    10,000 Gal. Inground Plaster Lap Pool
    Sand Filter
    New Orleans, LA
    Re: What's raising the pH?
    Do you have a lot of aeration, like from a spa, fountain, waterfall or several young kids? That will cause your pH to rise...
    All I remember about the term pH is something to do with the word 'potential' and the element 'Hydrogen'...
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    What brand of bleach are you using?
    P.S. pH is defined as the negative log of the hydrogen ion content. Lowercase p is the mathematical symbol for the log function and uppercase H is the symbol for hydrogen.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Jerry,
    What's your TA?
    You're done SLAMing when:
    Jan 2009
    Cupertino, CA
    1,966
    In a plaster pool using bleach as a chlorine source, pH will usually rise slowly. How old is the pool (or how long since it was last replastered, if you've had that done)? And of course what is your TA?
    Quote Originally Posted by stev32k
    Well, yes and no. It is a scaled negative log, that's why 7.0 is neutral. You can read various (not always consistent) descriptions of lowercase p on the web by googling pH.
    --paulr
    BBB "Intermediate Swimmer"
    Jerry's Avatar
    Aug 2009
    New Orleans
    48
    Quote Originally Posted by Butterfly
    Hi Jerry,
    What's your TA?
    Test shows 110.....I'm using WalMart bleach.
    The pool is about 15 years old and may have been replastered 5 or more years ago.
    I'm fishing out lots of oak tree leaves and acorns right now from my neighbors trees.
    I have no aereation devices but do have the four jets pointing against the pool wall and slightly upward. 2 on one side one way and the other side the other way...This causes the oak leaves to circulate in front of the skimmers and not bunch up in the corners
    Sand Filter
    New Orleans, LA
    Butterfly's Avatar
    South Carolina
    10,045
    Jerry,
    If you are having to lower your pH often enough to be aggravating, you could lower your TAto help slow the pH rise.
    The positioning of your jets could be causing aeration, but you seem to need that positioning to deal with the leaves.
    Also, as PaulR pointed out, pH rise is the nature of the beast when using bleach as the chlorine source
    While we got you on the phone, why don't you post a full set of #'s for us to peruse?
