Thread: Reassembling Sta-Rite Pumps
    I know there must be a trick to this. I am in the process of replacing the O-rings on my pool and spa pumps, both the small ones that go around the center of the impeller, and the larger (about 9") ones that seal the motor and impeller side to the strainer basket side.
    I have swapped the O-rings, looks like they are the correct sizes put what do I need to do to squeeze the two sides together enough that I can start to tighten down the metal ring that goes around the outside? It seems like I need the gap to be less than about a 1/4 inch to seat the metal ring, but at the moment it is more like 3/4 inch. Does it help to remove the motor by removing the four bolts or am I just asking for more of a headache?
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: Reassembling Sta-Rite Pumps
    Put a little lube on the diffuser oring (small one). That will allow you to slide the diffuser into the volute housing. If you don't lube that, it ain't goin in.
    Factory Warranty Station for:
    Aug 2007
    near the swamp
    806
    ^^^^what he said, it also helps to use a pair of C-Clamps to hold it together while you get the metal clamp in place.
    fordsbyjay's Avatar
    Sep 2009
    Lafayette, LA
    64
    Put some parker o-lube on your o-rings. I fought mine like crazy tell it donned on me the o-rings were dry and sticky. It slipped right in after.
    19000 gallon inground fiberglass pool
    Hayward Pro Series Sand filter S244T 62 gal/min
    Whisper Flow WFE-2 / 011511 1/2 hspr pump
    Aqua Rite AQR Pro SWG, T15 cell for 25000 gal
