Thread: Check Vavle and Pool Closing
    Aug 2009
    Chesapeake, VA
    18
    Getting ready to 'close' my pool for the first winter that I've owned it. SInce I'm in an area that rarely freezes at night, my plan is to clean/shock/algicide/cover the pool and set my timer to run the two-speed pump on low for 1-2 hours every night.
    I've been experimenting with the pump and my main concern is that the pump wont prime when the timer turns it on at night. Previous owners (orginal installers) ran the pump 24 hours a day so this wasn't an issue. Should there be a check valve before the pump inlet? Would one make the pump priming easier? The pump primes relatively quickly on high speed but I haven't run the pump more than 30 seconds waiting for it to prime on low for fear of damaging it.
    Also, should I set my 6-way valve to recirculate or filter during the winter? Will the filter even be effective or just become air-bound from turning the pump on/off?
    38,000 gallon IG vinyl-lined pool
    Pentair FNS Plus 60 DE filter
    CompuPool 48 SWG
    Solar Heat
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Check Vavle and Pool Closing
    Quote Originally Posted by pointledge
    This does sound a bit odd. In my configuration, there's no check valve before my single-speed pump, which is about 1 foot or more above grade and perhaps 1.5 ft above water level. It will lose prime only when I open the pump filter basket lid for cleaning -- or the filter pressure release valve is opened. Not sure what type of pump you have... my Hayward TriStar is self-priming to the extent that it takes about 10-15 seconds to gobble up enough water to do the job once turned on. This is a bit of a long shot, but is there any way to start the pump on high before continuing on low?
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    30,432
    If you are losing prime when the pump is off, you have a leak in the system. If you cannot find any wet spots between the pump and the returns, it is very likely a suctiuon side leak.
    Can you see any bubbles in the pump strainer basket when the pump is running?
    Aug 2009
    Chesapeake, VA
    18
    Only a small amount of air is ever in the pump filter basket area... When I turn the pump off though, all the water flows out. Is this bad/wrong?
    If there is a leak, I suspect it is from the filter. The pressure guage/air relief thing on top of the filter is likely the culprit... I might look at replacing that over the winter. I need to get into the 6-way valve this weekend and replace the spider gasket as I'm leaking water to waste slowly. Not sure if air could be entering there as well when the pump is off.
    FWIW, my pump is probably 1-2 feet above water level.
    CompuPool 48 SWG
    Solar Heat
    30,432
    Yep. A properly functioning system will allow no air to enter the system when the pump is off.
    If your multi-port is leaking water, that is at least one source of the air.......it sounds like you may have others.
