Thread: High bromine levels - What do do?
    I got my Taylor test kit today and here are my results:
    CH: 200
    TA 120
    pH 7.8
    Bromine 12.5ppm
    So I added acid to drop the pH down (I realize this will lower the TA as well). I am using a bromine floater and I just did my weekly shock two nights ago. I need to wait until the bromine is at 6 or below to get in right? What do I do now? Is my floater set too high? Did I add too much shock?
    Also, rereading the initial start-up instructions provided by our spa dealer, it didn't say to add sodium bromide to form a bromine bank. It only said to add MPS shock, which I did and then I threw in the floater. Everything I've read on these forums, say to add the sodium bromide on start-up. Would not doing this have an impact on anything? Should I go buy some and add it in?
    I'm confused.
    Michy
    13,500 IG Pool w/Spa, 50/50 Quartz/Plaster
    Whisper Flo pump, Booster Pump, Triton II Sand Filter, Pentair Model 320 Chlorine In-line Feeder, Ulta-Pure (Turbo Shock/UV ozone generator), Sta-Rite Max-E-Therm gas heater
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: High bromine levels - What do do?
    If you don't have a bromide bank to start with then the bromine tablets will build one up over time, but you might not have much "reserve" to be able to shock to get to higher bromine levels. Right now, that doesn't seem to be a problem. The bromine tablets add bromine (or bromine and chlorine, the latter reactivating additional bromine from bromide).
    You might have added too much shock or your bromine feeder might be set too high. Take out the feeder and monitor the bromine level which should drop in a day or two. Then, put the floater back in and see how things go as you use the spa. If the bromine level is fairly constant, then great. If it tends to be too high or too low, then adjust the feeder. You may not need to shock very often if your bromine level is more constant and your water stays clear. If you do need to shock to keep the water clear, then you may want to lower the bromine output on the feeder so that the bromine level is on the low side so that when you shock it's not too high.
    Don't worry too much about getting it exactly right. You just need to learn your tub's specific needs and adjust as you go along.
