Results 1 to 7 of 7
Thread: Bubbles from return while solar runs
    dayhiker's Avatar
    Jun 2008
    Pell City, AL
    304
    I have a constant flow of bubbles from the return nearest my pump whenever solar is running. It hasn't done this until the last month or so. Any advice or suggestions? I don't have any leaks that I'm aware of other than the slow drip I've had since day one. It drips once ever 8 seconds.
    The avatar is Spalding from Caddyshack
    18x36 vinyl IG - approximately 24000 gal
    Jandy SHPM1.5 Pump (1.5 HP); Jandy APURE 1400 SWG; Polaris PB4-60Q Booster Pump; Jandy CL340 Cartridge Filter
    (3) 4'x12' Aquatherm solar panels
    Next project, pump sound enclosure and lots of pool landscaping [6tons of stone 8) funnnn]
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Bubbles from return while solar runs
    Try slightly restricting the flow to the panels.
    dayhiker's Avatar
    Jun 2008
    Pell City, AL
    304
    Thanks. I'll give that a try. Any idea where the air is coming from to produce the bubbles?
    Vero Beach, FL
    462
    It is odd that you are only getting bubbles when going through the solar. The panels are on the return side and so any holes would have water coming out rather than air going in. Although without knowing exactly the setup, it would be hard to know for sure.
    Did you check the vacuum relief valve? Are you sure it is not just purging air from the panels? Can you divert all the flow to the panels and after a couple hours you are still getting bubbles?
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    dayhiker's Avatar
    Jun 2008
    Pell City, AL
    304
    If I leave them on all day I still have bubbles at the end of the day. The panels are on top of my deck roof. The downspout that serves that roof is bone dry so I'm pretty sure I don't have a leak up there. I thought I'd get up on the roof and check the valve you mentioned though.
    SW Indiana
    9,199
    Sometimes the panel restriction combined with very little restriction beyond the panels results in the outlet pipe to the returns not staying full. By diverting a little flow around the solar, the problem goes away.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Has the pressure in your filter changed at all?
    Mark
