Thread: High pH in Bromine hot tub (stand alone)
    Aug 2009
    Keene, Texas
    Now that I am getting my pool under control, I am considering using BBB for my hot tub. However, most hot tub dealers recommend Bromine instead of Chlorine. They say it is more stable in the hot water. I did start checking my bromine and pH myself tonight. My pH is extremely high. I was wondering, is it okay to use MA to lower pH in a Bromine hot tub? The pH decreaser I have been buying does not work well. any recommendations on BBB vs Bromine are welcome.
    Additionally, If I decide to just do the chlorine then do I have to drain? Or is Bromine close enough to chlorine that I can just switch?
    amoses (Aaron)
    Converted from Baquaqoo in the fall of 09. Best thing I ever did!!
    AG, 24 Ft Round, 54" wall, 48" deep, 13,500 gal., TF-100 test kit
    Hi-Flo II 1.5 HP pump, AquaTools High Rate 200# Sand Filter AT3120
    Jan 2009
    Cupertino, CA
    Re: High pH in Bromine hot tub (stand alone)
    BBB works well in a hot tub, that's what I do. I have never tried bromine so I can't offer any help there. But, I believe that if you already added bromine, then you are stuck with it until your next water change.
    If you look in Pool School, near the bottom is a Further Reading article, and near the bottom of that are pointers to articles about using chlorine and bromine in a spa.
    The main issue with using muriatic in a hot tub is that you need fairly small quantities and that can be a little tricky to manage without spilling. I use dry acid (sodium bisulfate) a spoonful at a time works fine.
    BBB "Intermediate Swimmer"
