Results 1 to 7 of 7
Thread: Pool Lighting
    Pool Lighting
    First of all, thanks for the excellent advice I have received so far! This question is about lighting. I am having a 16x24x42 L-shaped pool installed soon and I was wondering if one standard (low voltage) light is sufficient? The standard is to put the light under the diving board on the deep end shining along the 42 ft but that doesn't cover the L portion. Not sure if a second light is worth it. Thanks for your opinions!
    inground liner Grecian "L"
    26000 gallons
    1 HP whisperflo, TA100 sand filter
    Autopilot digital SWG, SC-60 cell
    Hayward Colorlogic LED lights
    30,426
    My rectangular pool has two 500w 110v bulbs and it is certainly not too much. I would absolutely consider more lighting than is currently planned.
    From_Arizona's Avatar
    Glendale, AZ
    212
    I would opt for more lighting if you can. I am installing two lights for my 34' x 17' rectangular shaped pool.... I will be using pebble-tec for the interior so much of the light will not reflect.
    1980's Shasta built 30,000 gal inground diving pool. Pebble-tec interior. Pentair DE Filter. In ground pop-ups. Hayward Navigator sweeper.
    Mar 2007
    Coastalish 'down easter'
    4,160
    When we install a lazy or regular 'L' pool we put one in the center of the deep end (ie, under the diving board) and one directly across from the steps -- having the steps and break illuminated is quite important for night use!!
    Luv& Luk
    -Ted
    Arizona
    924
    Definately and especially because it's L shaped.
    I have a 40' odd shaped pool with one light at the end. It's really not enough for even my pool at the opposite end.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Just swim in the dark, save money on bathing suits!
    Jim
    That's the only advice that haven't had any trouble understanding.....thanks! :P
    26000 gallons
