Thread: Heater Inside the Jandy Power Center
    Jul 2009
    Long Island, NY
    267
    Hello. I will be closing our new pool for the first time and have a question regarding the best way to protect our costly Jandy Purelink Power Center over the winter. I am an engineer in the electrical construction industry and it is common practice to install a light bulb inside electrical equipment enclosures prior to them being energized. The heat from the bulb keeps the inside of the enclosure warm and dry.
    I am considering using a small light bulb (say 25 watts) inside of the enclosure to keep it dry over the winter months. Has anyone done this? Does anyone have any other suggestions to protect the Power Center?
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Heater Inside the Jandy Power Center
    You're done SLAMing when:
    22,548
    I read this when you first posted it and was hoping someone would come along with a great idea. Apparently not!
    I too being a E² have experience with heating enclosures. We never use light bulbs but instead use purpose built enclosure heaters. Go to www.Omega.com and you'll find some inexpensive ones with thermostats
    The SRFE is a favorite of mine.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
