Results 1 to 9 of 9
Thread: Accuracy in Testing
    Jul 2007
    Hillsborough, NC
    525
    Accuracy in Testing
    I have one of the liquid-drop type kits that tests for chlorine, pH alkalinity and acid demand. I tested Monday night and got:
    7.6 pH
    140 PPM alkalinity
    I tested last night and got:
    7.6 pH
    130 PPM alkalinity
    I took a sample to the pool store today and got
    8.0 pH
    53 alkalinity
    Chlorine being low I understand. I need stabilizer and I am fighting some algae.
    Now it rained overnight so that could explain why the pH drifted up, but alkalinity is way off. I realize the test is subjective regarding color changes but that is a huge difference. Could the rain make that much of a difference?
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Montreal Canada
    326
    Re: Accuracy in Testing
    If it's a Taylor test kit the error margin for the alkalinity test is 1 drop, so if you used a 25 ml sample this is 10 ppm, so you're within tolerance. The endpoint of the alkalinity titration is very a sharp and vibrant red leaving very little room for interpretation. I wouldn't trust the 53 alkalinity the LPS measured.
    Jul 2007
    Hillsborough, NC
    525
    The test kit is a generic Ace but the sample size would be about 25 ml. I'd understand a few points difference withe LPS, but 80?? I will retest tonight before I treat for alkalinity. Again a little subjective but that is a huge difference. I tested last night and pulled a water sample this morning but did not test again. The rain overnight may have screwed things up.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Your alkalinity is fine unless you are struggling to keep your pH down. My fill water is over 400ppm TA, so I know high TA. This is the first year ever that my TA has been less than 180ppm.
    Some pool store tests can be wildly off. The amount of training the staff has and care with which they do the tests varies quite a bit, even at the same store at different times. I would trust your results.
    30,432
    Crokett,
    You indicated an algae issue but haven't said anything about adding chlorine....you are, right?
    Jul 2007
    Hillsborough, NC
    525
    Duraleigh. yes I am. Tonight I will vac out as much as I can, add the stabilizer and shock. By the way, since I am in your area, the place I went is Poolside. They were recommended.
    This latest with the test kit is just one more thing that gives me more questions than answers.
    30,432
    As you learn more and more from this forum, you will see just how inaccurate pool store testing can be. Measure and test accurately and trust your own results.
    Jul 2007
    Hillsborough, NC
    525
    Well actually I think this was my screwup this time. I tested again twice this evening (it was getting dark last night) from different parts of the pool and came out with 70PPM and 60 PPM. Neither of those is that far off from 53. I still say my pH is fine. They measured it at 8, I came out with 7.6 both times.
