Results 1 to 7 of 7
Thread: Can I *please* just drain my pool?
    Jul 2009
    Phoenix, AZ
    4
    It was replastered last year - we're not using it anymore. We live in AZ - temps very rarely get below freezing.
    If it is a REALLY bad idea to drain it, can I just let the water sit for the next few months, or will it be totally gross and smelly?
    15000gal IG plaster pool, cartridge filter
    30,432
    Re: Can I *please* just drain my pool?
    Neglected Pools don't do well....(just like pets or anything else that requires some maintenance).
    If you neglect your pool, the fix-up will likey be much harder than simply maintaining it properly to begin with.
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, what Dave said.
    Also, cooling temps will be coming which will reduce pool maintenance and expense.
    If you want to tell us what questions or problems you have, we can probably help
    You're done SLAMing when:
    Guest
    The nature of plaster dictates that it must remain submerged or it will start to release (delaminate) from itself. Chances are that you paid quite a bit to have it plastered and you will ruin it if you drain it. The money you save in chemicals and circulation will not be close to what it will cost to re-plaster again! Don't do it!
    Bruce
    Jul 2009
    Phoenix, AZ
    4
    Well our problem is just laziness. I think we might have a leak, too, but I haven't done the test for that yet.
    Would it be okay if we just kept up on chlorine, ran the pump every so often, but didn't clean out debris that sinks to the bottom? Also... we have a katchakid net on top, but is there an inexpensive cover we could put on top of the water to keep most of the debris out for the next 6 months?
    ~thank you~
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by azPOOLnewb
    You may find that the cover doesn't keep enough debris out (for instance, when the wind blows...) For minimal maintenance, suggest not covering the pool during the winter, use an automatic pool cleaner that runs the entire time you're filtering, but keep the filter time short. Of course, you'll want to keep chlorine in the pool, to oxidize the dust and other debris that the cleaner misses. Either way, unless there is no plant life within a hundred miles, I don't know how you can avoid checking/emptying the skimmer(s) and pump filter baskets on at least an occasional basis.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    ~thank you~
    Depends what your definition of inexpensive is but you may want to get a mesh leaf cover to put on top of your safety net. That will keep the bigger stuff out at least.
    Love TFP? Become a
    TFP Supporter!
