Results 1 to 11 of 11
Thread: eyeball removal tool?
    May 2009
    Trenton NJ
    497
    I finally found one but it did not work. The way my return eyeball is designed,the eyeball does not screw out, it is held in by the ring that screws into the port. So you cannot use the tool with eyeball in place,so what i bought is useless.
    Is there a tool that would work for this situation,or can I retrofit my returns with new eyeballs?The only way I could get them out is to use a hammer and pound a screwdriver to the rings,some of the plastic around the ring gets damaged and sooner or later I will need new ones.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: eyeball removal tool?
    Try using needle nose pliers to lock onto the ring
    Luv& Luk
    -Ted
    i don't know if i understand what you're asking or not, but i asked a pool-friend the same question, about how to get ours out, and he said to unscrew the outer part (that sticks out into the pool, that you can sometimes unscrew just by hand) and then to use a wooden paint stirring stick, like from Home Depot, to wedge inside the larger opening to use as a lever to unscrew it. it worked for us!
    if that's not what you needed to know, i'm sure someone else around here will give you a better answer
    Inground, Vinyl 18x37 Grecian (probably 23,000?)
    1 HP Pump + Hayward C900 Cartridge Filter
    "rigged" aboveground plumbing.
    Mantua, NJ
    80
    I had to use channel lock pliers before.
    If you wrap the threads with teflon tape, this will make removing the eyeballs easier. I forgot to wrap the pressure cleaner adapter in the spring. Needed the pliers and already wrapped the threads for next year.
    Joe
    21k IG vinyl, 300 lb. sand filter, 1hp pump, Polaris 280 cleaner, 3/4hp booster pump, 240sq ft Fafco solar, Liquidator
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    The biggest problem I had was I couldn't get a good enough grip to turn mine by hand until I put a rubber/nitrile glove on. After that, I had no problem whatsoever getting a grip and getting them to turn.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    DaveNJ's Avatar
    Toms River, NJ
    520
    I use a Quickgrip small rubber strap wrench. I use it on stubborn pvc couplers also.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    I butchered one up pretty bad not long ago. Unusable, ended up replacing it. What worked?
    Shoving in a rubber winterized plug, and unscrewing. Plan on using one again if I have any trouble closing this weekend.
    Greg
    Kansas City, MO
    13500 gallon Foxx vinyl sport pool--inground (1988)
    Cristal-Flo sand filter
    Ray-Pak 406A digital
    1.5 HP single speed
    400 gallon Heldor inground spa, octagon
    May 2009
    Trenton NJ
    497
    I wonder if there is a lube you can use that might help. At this rate I will have to replace every couple of years. I don't know why they are so tight.
    Mar 2007
    4,160
    A couple wraps of Teflon tape will help prevent 'sticky eyeballs' (as per Joe )
    Luv& Luk
    -Ted
    Oct 2013
    Texas
    17
    Sorry to dig up such an old thread, but had a similar question and thought I would add some relevant information to the one post I could find that seemed to directly address it. I have a few eyelets that I have some stubborn rings I can't get to budge (partially because they are at the edge of reach in cold water), so have been searching for the same. Looks like something like this would work, but I have an old cheap set of needle nose pliers I might sacrifice to potential rusting first:
    Eyeball Return Jet Removal Wrench Discounter's Pool and Spa
    Feherguard Eyeball Wrench Our Pool Store- FREE SHIPPING
    For removal of the inner eyeball seat area (which I do not need to do but seems to be the only thing that comes up in any search I do for removing the ring) - I happened across this site that has some overkill but nifty specific tools for this:
    http://www.toolsforpools.com/lassent...at_Wrench.html
    The solid aluminum ones seem to be great if over-engineered solution for these simple issues and the ESW-2 looks like the back end of it would also remove rings as well.
    20,000 gallon in-ground gunite pool with Stonescapes Aqua Blue Regular Pebble, 4 rock spillway water features
    Aqualink RS-PS8 w/iAqualink Controller, Jandy E-Pump 2.0HP, 60sqft Jandy DE Filter, Polaris 3900 Sport cleaner w/PB4-60 booster pump, Chlorine tablet feeder
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,376
    Those are all nice tools.. I have owned them all,
    the metal tools have gone MIA on me.
