Thread: How I dealt with algae issues
    Aug 2008
    Ocoee, Florida
    12
    Post split of from this topic
    I live in Florida, and your pictures look exactly like what I have, except I have the leaves to go with it. (You commented on my post about the PoolSkim). We have a very large oak tree in our yard and all of our neighbors have oaks. I'm still not sure if it's pollen or algae, but I treated it like algae, just in case. I have had problems every summer since we got the pool, but this year has been the worse. Right now, I have a clear sparkling pool, but it's only been a week, and I have been checking it every day.
    I'll tell you the best thing I did to help myself was to get the proper test kit. When I finally got the test kit and tested the water myself (compared to Leslie's tests), my CYA and FC were very, very high. I spent two days draining water off and refilling it to bring my CYA down to an acceptable level. Then, I was finally able to keep the water clear. Well, at least it's been clear for a week now. It seems like I had put so much in the pool trying to fix it that I made it worse and almost had to start over by draining and refilling. (btw...I only use the BBB method now.)
    The other thing I am trying, that you may want to try, is I am adding Borates (Borax). I just put it in yesterday, but I swear the water seems softer and more "crystal-like". I'm hoping this helps with the algae sensitivity, but it can't hurt. Here's the link if you want to consider it: so-you-want-to-add-borates-to-your-pool-why-and-how-t4921.html
    Several claims have been made for these products when used in a 30-50 ppm concentration such as:
    1) more stable pH
    2) Algaestatic properties
    3) reduced chlorine usage
    4) silkier feeling water--less skin and eye irritation
    5) clearer, 'sparkling' water
    In the past, if I didn't check the pool for a day or two it would turn yellow again. I am hoping I finally have everything under control. I'll let ya know.
    Michele! =)
    10,000 gallon
    15' x 26' Oval AG
    26" two speed sand filter
    Mar 2009
    Charlotte, NC
    539
    Re: Pictures look like pollen or algae?
    michelbie - sounds like you are doing great.
    Part of the BBB is to check it daily so I hope you are now. Especially in a warm climate like Fla I would think it easier for things to get out of hand.
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Aug 2008
    Ocoee, Florida
    12
    Thanks, Johnny B. It is looking really good now. I haven't checked my chlorine since Thursday, though. I've been running the pump for 24 hours and vacuuming every day. Hopefully, with the Pool Skim that I got Friday I'll be able to cut back on vacuuming the leaves out every day.
    This is a great site to have as a resource. Without it I might have given in and taken the pool down (or the tree).
    My family is enjoying the pool right now and they say it is like bath water.
    Michele! =)
    10,000 gallon
    15' x 26' Oval AG
    Aug 2008
    Ocoee, Florida
    12
    Re: How I dealt with algae issues
    My pool has been crystal clear for two weeks now. I think that's a record. Thanks, TFP!
    Adding the borates really helped, but getting the chemicals under control is what helped the most. Before, I thought I could just add chemicals and check it every once in a while. But, it turned out to be more time consuming than just checking my chlorine levels every day. I have maintained my FC at 5.5 for the last week and it only takes a few minutes to check and add some bleach. And, it is much more satisfying seeing my pool nice and clear everyday.
    Thanks, again.
    Michele
    Michele! =)
    10,000 gallon
    15' x 26' Oval AG
