Results 1 to 14 of 14
Thread: Help! Frogs & Frog eggs everywhere!!!
    OK, well thanks to everyone's advice we now have a clean and clear swimming pool. However, when we initially shocked the pool it was basically a mass murder on the local frog population.. We probably pulled out 4 or 500 dead tadpoles and close to 20 full grown frogs. We thought we had wiped them out, but we were wrong...
    Every morning I check the pool out and skim it and every morning I see all of these little black dots that are everywhere. At first I thought it was just dirt, but after seeing (and hearing, ugh) all of the frogs that come out at night, I realize its either 1) Frog eggs or 2)Frog poo.
    So after googling for an hour or so and realizing that everyone in the world is a frog lover and would like for me to let the eggs hatch and safely relocate each and every little frog, I come to you. I need to take back the pool from the frogs! Can you help me??
    Thanks
    Allan
    25,000 Gallon IG pool with 1HP Sta-Rite Pump and Pentair Clean & Clear 150sf Cartridge Filter
    30,432
    Re: Help! Frogs & Frog eggs everywhere!!!
    I suggest you have a meeting with the frogs this evening. Tell them you intend to elevate your level of chlorine by about 25% above normal, that you will be brushing frequently and running your pump (filtering) 24/7.
    They are not the sharpest ones in the animal kingdom so you should further explain this environment you intend to create will not be conducive to raising a froggie family.
    I would also suggest an alternative location for them......they don't seem to think well for themselves. Perhaps you could post a map near the edge of the pool pointing out the nearest pond or swamp.
    This new environment you create will soon dispose of any current eggs (they have more) and I feel confident they will eventually get the message and move on.
    Now, I have hundreds of toads all summer that jump in my pool at night. As we all know, toads are much dumber than frogs and I have been unable to communicate my wishes to them at all. Perhaps if you shipped me a few frogs I could get them to talk to the toads.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    LOL too funny Dave
    I would also suggest in addition to elevating the chlorine level, consider adding borates - eventually they might get the message.....
    Aug 2009
    North Central Texas
    1,358
    My pool was literally a frog pond most of 2008. We let the little critters mature and move out of the pool before draining and acid washing. I even put a ramp and tree branches in the pool to assist them "escaping". Theses were small leopard frogs.
    BIG MISTAKE.... Our copperhead population grew exponentially last summer. And we are still battling them. We catch, on average, one right at the house, weekly. About 20 so far this spring/summer. We have to keep the puppies out of the yards after dusk because of multiple bites this year.
    If you have any venomous snakes in your area having a frog pond can draw them in. BTW..... we love the nonvenomous snakes and frequently have a 7 ft RatSnake in our garage. EDIT I corrected this from Rattlesnake to RatSnake.
    I switched over to BBB last month and everything leveled out and beautiful. THANKS TFP Last week a frog laid a bundle, pod, or whatever you call it, attached to the line for the Aquabot. I removed them using a plastic glass and the whole bundle stayed together. Next day, another bundle "laid", attached to same location. DH (hubby) tried to pick bundle up with hand and the whole bundle came apart.
    Haven't had any more laid since then so I guess we have smart frogs.
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    I suggest you have a meeting with the frogs this evening [...]
    Absolutely delightful. I haven't laughed this hard since I don't when!
    abrown1213, take Duraleigh up on his offer... send him your frogs!
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Some real entertainment in this place, haha!!
    Well, I am not seeing as many eggs as I was last week, but they are still aroundand I even found a few swimming tadpoles... The chlorine is going up today!! Also, we are going to try and catch as many frogs as we can over the next week or two and take them to some woods a few miles away. Hopefully we can start to make some round on the issue that way.
    Don't they taste just like chicken?
    Rob B
    My $100 pool finally died after 6 years.
    Totally got our monies worth!
    Butterfly made me do it...
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Quote Originally Posted by geekgranny
    <snip>
    BTW..... we love the nonvenomous snakes and frequently have a 7 ft RattleSnake in our garage.
    </snip>
    Uhhhh..granny? Aren't rattlesnakes venomous???
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    X-PertPool's Avatar
    Exeter, PA
    1,385
    There is a product called 'scamper ramp' that will let frogs and animals stuck in the water an access out of the pool.
    There is also a product specialized for smaller frog like creatures called the critter skimmer http://www.critterskimmer.com/
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by MikeInTN
    <snip>
    BTW..... we love the nonvenomous snakes and frequently have a 7 ft Rattlesnake in our garage.
    </snip>
    OOPSssssssssss. I need to correct that to RatSnake. Thanks for pointing that out MikeInTN.
    Rattlesnakes are but RatSnakes aren't. We have a few Rattlesnakes (and the dogs got their Rattlesnake Vaccine) but haven't had any GIANT ones since a few years after the Lake completed filling, early 90's. RatSnakes are long, skinny snakes, that eat mostly warm blooded varmints and birds. They get up to and a little above 7ft when mature. Although they do have pretty nasty temperaments they are sold and kept as pets by some snake lovers. We have a white and black banded California King Snake pet who has a very nice temperament. I don't know why anyone would want a RatSnake pet though. We, also, have a pretty nice population of Texas Coral Snakes, that average 30" when mature. I have one in my freezer, that we caught last year, right at the house foundation. It measures 40". May be a record. People usually only get a bite from them when handling them because their mouths are so small and they do not have hinging jaws like pit viper so they can't bite anything much bigger than a finger.
    gg=alice
    Jul 2009
    Eden Prairie, MN
    37
    During the summer, I had a small green frog that lived in my skimmer. I would remove him and throw him far away in the yard over the fence. He always came back. I plugged up the skimmer lid hole and he'd swim through the skimmer water level door. I run the Cl a little high 8-10 ppm and he slowly bleached to grey.
    AGP partially buried, with surrounding deck and flower bed. 12 x 24 oval x 48" deep Celebration by Forum. Steel sides, vinyl liner. Hayward 2 HP sand pump. Flower fountain - works well to cool water up to 10 degrees.
    polyvue's Avatar
    Aug 2009
    1,215
    Quote Originally Posted by SBax
    Fantastic! Whether true or not, there's the beginning of a great short story here. What happened to the little grey frog?
    __
    Last summer, we began opening our pool for the summer season by taking the cover off. However, we had some delays in getting the chemicals into it, etc. So, one day, my boyfriend (Dan) was helping us out in cleaning the pool, and we noticed that there were a ton of tadpoles in the water! We spent the afternoon collecting them in the net and placing them in a bucket. We relocated them to the creek that runs behind our neighborhood. The next day, there was a frog in the pool. We caught it, and threw it into the backyard. The following day, there was yet another frog. This time, it was on the ladder (which was not yet in the pool), AND there were more tadpoles. This time, Dan took care of them. We proceeded to fill the pool and get it running, but all summer long, we kept getting frogs in the pool. Sometimes 2 or 3 in a day. They were almost all different in size or color, and in fact, we caught one to give as a gift to a friend's daughter. (she named him Phrog and he's still alive and kicking). We've always had trouble keeping the chlorine level in our pool up, and sometimes don't even really bother to keep it up as much as we should.
    Now, this year, we drained the pool due to debris that got in it over the winter, and it caused the liner of the pool to wrinkle. Rather than trying to fix the wrinkles and THEN washing off the debris, my idiot brother decided to do exactly the opposite. So, now, we have about a foot of water in the pool and are unable to pull the liner and get the wrinkles out. UGH!
    Anyways, this is about frogs...we've been hearing several frogs lately, but keep in mind, there's a creek not 20 feet from my backyard. Not that unusual. But, last night, one was exceptionally loud. So, I stepped outside and, sure enough, there was a frog in our pool. I wanted to catch it and give it to my friend as a second pet. However, by that time, it was too dark and I couldn't see to catch the lil guy....or girl. This morning, I went out to check on my froggie friend, only to find that it had vacated the pool. However, there were several small clusters of black dots. I knew instantly that they were frog eggs. Now, I'm wondering what to do. Can I relocate them to the creek without killing them, so I can fix my pool and have a cool place to hang out this summer??
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    As a sufferer from ranidaphobia, this concerns me greatly. One frog in the water and you will never catch me back again in that pool. I can't look at most of the websites that come up when I search for from deterrants because they normally have a picture of a frog somewhere and that is even too much for me.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
