Thread: Am I understanding this right?
    skydiva44's Avatar
    Houston, Texas
    200
    I have been told on here before it is safe to swim UP to shock level. I have been shocking this past week so my level is at 30 right now (I shocked high because I think it was mustard algae)so do we go by the normal shock number? A normal shock level would be 21 for my numbers, so I should not get into the pool until it is 21 or below correct? I really need to vacuum and it is so much easier being in the pool doing it than outside of it...Thanks!
    ABG Easy Set 18 x 48
    5455 gallons
    SWG
    Intex Pump 4000 GPM - Size B cartridge
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Am I understanding this right?
    While I wouldn't hesitate to hop in the pool with a 'slightly' high cl level, most folks here aren't as 'gung-ho' as I I think you should let the cl drop to your normal shock levels before hopping in.
    I think you'd be fine going in to vacuum - as long as you wore an old bathing suit, unless you like to vacuum naked If you're higher than normal shock level for your cya, the fabric and elastic in your bathing suit could be damaged, but going 'au natual' shouldn't be a problem :P
    Luv& Luk
    -Ted
    skydiva44's Avatar
    Houston, Texas
    200
    LOL waste...I just want to vacuum not get arrested! I'm not worried about a suit, I'm worrying about body parts falling off from all the bleach....lol
    5455 gallons
    SWG
    30,419
    Sky,
    There has, to my knowledge, never been a reported problem on this forum with swimming in very high FC levels. The Shock level limit is simply a guideline wherein it is perfectly safe. It is very likely perfectly safe to enter a pool w-a-a-ay higher than that but it starts to get into a gray area at some point......everyone has to choose that point for themselves.
    For what it's worth. the ppm level in your washing machine when you add bleach is in excess of 250ppm and that's with no CYA.
    skydiva44's Avatar
    Houston, Texas
    200
    Thanks Dave....I'm going for it!
    5455 gallons
    SWG
