Thread: winterizing
    winterizing
    how low do you drain your pool for the winter freeze?
    **Beginning full restoration soon**
    IG 25,000 Gallon 18' x 36' x 8' max depth, built ~1972
    Tagelus TA-60 sand filter
    Plaster, needs resurfacing, considering Ultraguard
    Plan to convert to SWG
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: winterizing
    usually below the return lines and skimmer so they can be cleared of water and capped off for winter. This is typically 12-18 inches from the top of the pool depending on the style.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Re: winterizing
    I am new to winterizing and am wandering? My pool package came with a pool cover that is for a 24 round pool real size 27 so if the pool is lowered down 18" this makes the winter cover to small??
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: winterizing
    It should fit. I have the same size.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    Re: winterizing
    Mine too. If you drain down too far...it might be tight but It should fit...mine does and I have 54 inch high walls...So it should work. Got Clips?
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
