Thread: Front wheel UP on Polaris 380
    Seems like there is no suction because the front wheel is not riding on the pool floor.
    Any adjustment to get this thing to ride flat on all 3 wheels?
    Thanks!
    15,400 gal with attached spa, IG concrete, FNS 60# DE, 2HP Pump, Gas Heater 400 BTU , 1.5HP Booster Pump, Polaris 360, Nature 2 (never use)
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Front wheel UP on Polaris 380
    Quote Originally Posted by YO-EL
    Hello YO-EL, and welcome to the forum.
    All of the 3-wheeled cleaners tend to ride on just 2 wheels some of the time, but if it happens most or all of the time there are several things you can adjust. Try just one at a time and give the cleaner a few minutes in the water to see what the effect is:
    • 1. Adjust the head float by pushing it in or pulling it out from the stem -- a few millimeters at a time
      2. Tighten or loosen the sweep hose adjustment screw to modify tail movement
      3. Set the thrust jet to 11 o'clock or different orientation if it's already set to 11:00 (this can have a dramatic effect on operation)
      4. Check and adjust, if necessary, the revolutions per minute (RPM) of the unit (to 28-32 rpm)
    For a slightly more detailed discussion of the last two items, see pages 5 & 6 in the Polaris 380 Owner's Manual
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    In addition...
    You could also have a clogged jet, which will give more pressure to the paddle wheel resulting in higher speed hence the wheelie. Also, when the bag gets too full it can act as a sail, in that, it will cause too much drag and will rotate the unit (wheel up).
    Factory Warranty Station for:
