Thread: How long to wait after adding bleach and muratic acid
    Jul 2009
    El Paso, TX
    27
    Hi all:
    How long should one wait to swim after adding a normal amount of bleach and muratic acid to maintain the proper level per the "Pool Calculator" ?
    Bill
    14,000 gallons; Sand filter; IG; Vinyl; Pump size and filter = TBD
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: How long to wait after adding bleach and muratic acid
    Quote Originally Posted by wmorton1
    Well, if your signature is up to date ("Pump size and filter = TBD") I'd have to say the answer is until the day you install a pump and filter! heh heh
    If you have good circulation (multiple suction lines and returns lines) good turnover rate (or PSI at the filter) AND you're not in the midst of shocking your pool for mustard algae etc., I suspect that the acid and chlorine additions would be pretty well diluted in 15-30 minutes or less. My practice is to dump chems in the deep end with 100% suction at the main drain, wait 5 minutes or so, then split suction 50-50 between main drain and skimmer and start up everything that stirs the water: the auto pool cleaner, spa jets & water features. If the surface needs netting, I do that. Another five minutes I turn everything off (or down) and jump in. So far, no skin burns to complain about.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    also never add muratic acid and cholrine to your pool at the same time. Always allow a min of15 minutes with the pump running between chemical additions.
    MA and chlorine do not like each other
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by dmanb2b
    Amen!
    The general rule at our house, and the recommendation I give here, is to wait 30 minutes before swimming.
    You're done SLAMing when:
    polyvue's Avatar
    Aug 2009
    1,215
    Quote Originally Posted by Butterfly
    A good rule... broken only by children, teenagers, college students, the elderly, dogs and insects.
    __
    Jul 2009
    El Paso, TX
    27
    Thank you all for your fast responses...now all I need are a pump and filter
