Thread: High Borates
    Mar 2009
    Galveston, Tx
    16
    High Borates
    I added borates to my pool according to the directions about three weeks ago, but the borate strip reading is greater than 50. How do I calculate the amount of water I need to replace?
    TC 7
    pH 7.3
    T/A 70
    CH 200
    CYA 65-70
    23 K Gal
    DE
    IG
    gunite
    2 Hp Pentair pump
    Filter: DE Nautilis FNS 60
    Montreal Canada
    326
    Re: High Borates
    Quote Originally Posted by mcase
    TC 7
    pH 7.3
    T/A 70
    CH 200
    CYA 65-70
    Say you're at 80 ppm borates and you want 50, the fill water has 0 ppm borates:
    (80 - 50) ÷ (80 - 0)
    30 ÷ 80 = drain and refill about 37%
    Another example, if your CH is 600, you want 300 and the fill water is at 50 ppm:
    (600 - 300) ÷ (600 - 50)
    300 ÷ 550 = drain and refill about 55%.
    30,414
    Re: High Borates
    Calculate the percentage of borates you wish to remove from your pool and remove the same percentage of water.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: High Borates
    I realize this is not the question you asked, but if you only overshot a little, (like maybe up to 80).........you might want to read this thread instead of adjusting:
    so-you-want-to-add-borates-to-your-pool-why-and-how-t4921-100.html?hilit=borates%2080
    You're done SLAMing when:
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: High Borates
    So long as you are measuring under 80 ppm, I wouldn't worry about it.
