Thread: Increase in CYA following rain???
    I have been successfully maintaining the CYA level in my pool between 40 and 50 for several months. We keep our FC levels a little high because of a hx of black algae. This has worked well for several months.
    So I had stopped testing the CYA level frequently since it had held steady and I have NO sources of CYA adding to the load. I use liquid chlorine only.
    Recently we had a series of thunderstorms that added maybe 1" or 2" at most to the pool. I didn't think to check the CYA level afterwards because a slightly lower CYA level would be fine. It's higher I don't want to do. Did have to adjust the pH down a little more than usual.
    So about 5 days after the rain we notice a resurgence of the black algae. Very small spots but definitely an increase in growth.
    I raised the chlorine level up to 30 for 3 days (FC stayed steady overnight) and did heavy brushing, etc. and the algae retreated but then resurged again once I dropped the FC back down to 8.
    So I just checked my CYA level (had to go buy more reagent) and it's up to 90!!!
    The ONLY thing that could have done this was the rain. But I thought rain diluted CYA not increased it.
    Anyway, I am doing a partial drain and refill but was wondering if anyone else had seen this.
    After refill I will recheck and adjust numbers as needed. Probably drop the pH to 7.2 and increase FC again.
    Patricia
    Plaster pool 17000 gal, Hayward pumps w/4 cart filter, Jet-vac sweep
    TC 8
    FC 8
    pH 7.5
    CYA 90
    CH 250
    TA 80
    17,000 gal IGP, White plaster, Hayward Swimclear Cartridge Filter system, Sta-Rite Max-e-pro 1/2 hp pump; 3/4 hp booster pump
    Sacramento, CA
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Increase in CYA following rain???
    Sounds like someone added CYA somehow, via a granular shock product or tablets.
    Rainwater would dilute the level, not increase it. Testing error is always possible - did you do the test under the same lighting conditions everytime? The test is so subjective....
    30,408
    Yep. CYA does not occur in nature. The only way to get CYA in a pool is for someone to somehow put it there.
