Thread: 2 Speed Sap pump only runs on low speed
    My Challenger 2 speed Spa pump motor only runs on low speed, even if voltage is applied to the high speed terminal. I disconnected all wires from motor terminal block. I measured resistance between high and low speed terminals. No resistance, just pure continuity. Is this indicating something wrong inside the pump motor?
    Thank you,
    Dale
    First time owner, 15k gallon inground, Pentair FNS36 DE, just installed Hybrid-Pump X2, Solar Heater, PoolCleaner, FT100 kit, BBB, brood of six.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: 2 Speed Sap pump only runs on low speed
    First, welcome to the forum.
    Most motors will have only a few ohms of resistance in the windings so when you say "no resistance", did you set the meter on its lowest resitance setting? If it is indeed 0.000 Ohms then the motor is probably shorted but then the breaker would shut off. Are both windings this way? It is possible that the start capacitor may be shorted but again, the breaker would trip.
    Mark
