Results 1 to 9 of 9
Thread: How precise does TA need to be?
    TimS's Avatar
    Sep 2009
    Central Missouri
    214
    I put a new vinyl liner in my pool at the beginning of September. I'm still trying to get the TA in line. (I'm not yet using BBB, but plan to for closing and next summer. I hadn't heard of BBB until after I had the pool filled, and had started chlorinating with lithium shock and trichlor.)
    My starting TA (tap water) is over 300. I've finally gotten it down to 140. I've been aerating for several days, and have been keeping pH between 6.8 and 7.8. When the pH gets above 7.5, I add more acid. Typically this drops pH to 6.8 or 7.0, and a few hours of aerating brings it back to 7.0 or 7.2. It takes quite a bit longer to get from 7.2 to 7.5 than it does to go from 6.8 to 7.2.
    The recommendation in Pool School for TA in a vinyl, bleached pool is 70-90+. OK, how high is '+'? Is 140 an acceptable level or do I need to bring it down further? What's the impact of high alkalinity when closing, and is 140 actually high?
    As of this morning:
    CH - 200
    pH - 6.8-7.0
    TC - 5
    TA - 140
    CYA - 80 (this number is actually a few days old. I didn't test this one this morning.)
    These numbers are from an HTH drop kit. I don't have my TF100 yet
    So far, I've added about 10lbs of dry acid, and 2.5 gallons of MA. Based on the current rate of change, it will probably take another 1-1.5 gallons of MA (and another week) to get under 100.
    TIA
    24' AG Round (vinyl replaced 0909) - 13500 gal - Sand Dollar Filter (150lb) - Dynamo DYNII-N1-1 1HP - Hayward HP380 Heat Pump - TF-100.
    Central Missouri
    Before I speak, I have something important to say.
    H2O_Keeper's Avatar
    Nov 2008
    SW Indiana
    140
    Re: How precise does TA need to be?
    The biggest thing about a high TA is that your PH will drift up more if it is not in the recommended TFP ranges. I have high TA in my fill water as well and after adds and I get up to 150 I find myself adjusting the PH 1x a week to lower with MA. When I have it at 80 I have to adjust it maybe once a month. IF you are about to close for the winter I would not worry about the TA till the spring.
    Also as a side note I see the same thing with a fast PH rise when its low 7's and slow above 7.2....I just hit it at 7.2 and take it a little below 7.0 and keep doing it. I have to add acid more often but I get it done quicker.
    21K Gal, IG, Vinyl, Bleach-Borax-Baking Soda, 3/4HP Hayward pump, Hayward sand filter, 200,000BTU Heater, TF100 Testkit
    "All that we are arises with our thoughts." - Buddha
    “When fate hands you a lemon, make lemonade.” - Dale Carnegie
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    140 is not that bad, unless you are using an SWG. If you experience rapid PH rise, then lower it further, but unless it causes a problem for you in the PH department, I doubt you will have an issue. My TA was rock solid 120 for two years and it did nothing to my PH.
    I would suggest that with the TA of 140, if you close with your PH around 7.0-7.2 you should be fine when you open in the spring, that it's okay to close at that level. Shouldn't be a problem.
    30,421
    Yeah, if you are around to test it, the TA reduction will go quicker if you stay between 6.8 and 7.2. As I,m sure you know, not a good practice to go below 6.8 during the process.
    TimS's Avatar
    Sep 2009
    Central Missouri
    214
    Thank you all. That helps.
    Are you saying that MA is more effective at lowering TA if the pH is lower to begin with? I don't really have a handle on the relationship between pH and TA yet, only what I've read in Pool School and the knowledge imparted by the people on this board. I didn't pay enough attention in high school chemistry, and even if I had, it's been a day or 10,000 and I would have forgotten it by now.
    On a semi related note, is it possible to lower pH without lowering TA? Since acid lowers both, but aeration raises pH and not TA, is is possible to get a high pH that needs to come down but to have a TA that is already low enough that you don't want to lower it further? If so, how would you fix it? I'm thinking about next summer. The kids love the fountain, but this summer I didn't know it would change pH. I didn't run it enough to matter, but since the kids have discovered it, they really want it on a lot.
    Central Missouri
    11,969
    Yes it's possible. And you are correct, acid lowers both.
    You would lower the PH down to 7.2 ish and then use Baking Soda to raise the TA.
    When raising PH and/or TA:
    baking soda - raises TA lots and PH a little
    borax - raises PH lots and TA a little
    washing soda/soda ash -raises PH lots and TA some
    aeration when TA is high - raises PH without changing TA
    TimS's Avatar
    Sep 2009
    Central Missouri
    214
    Quote Originally Posted by frustratedpoolmom
    This quote from Jason looks familiar, but I don't recall where I might have seen it. Is it somewhere in Pool School?
    Central Missouri
    11,969
    Not sure - I have it bookmarked from an earlier post. The basics of it get repeated enough, probably why it's familiar.
    TimS's Avatar
    Sep 2009
    Central Missouri
    214
    That quote is one of the things that I now have posted inside my supply cabinet where I can find it easily. Thanks.
    Central Missouri
