Results 1 to 9 of 9
Thread: my test results and closing pool
    Aug 2009
    SW Wisconsin
    518
    Hi all, I am fairly new to pool ownership (well at least a large pool)...I just took some tests today on my pool with my TF-100 test kit, and wanted to post them, to see what I would need to do yet to close it up for the season.
    09/24/09
    Temp = 68F
    FC = 4.5
    CC = 0
    pH = 7.6
    T/A = 320
    CH = 180
    CYA = 40
    I know my alk and CH are still a bit high, and I've been aerating to bring down the CH..and it's been working. Any thoughts??
    Dan
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Re: my test results and closing pool
    I would focus on lowering your TA to at least 120 to avoid PH rise in the off season, then follow the closing your pool instructions in pool school. The lowering your TA instructions are also described in detail in pool school.
    30,400
    Hi, Dan,
    Are you aware of the static electricity issues with the TA test?
    If your R-0010 drops appear smaller than the drops from the other bottles or they seam to "jump" off the droper tip, wipe the dropper tip with a damp cloth every two or three drops and that will fix that issue. Your TA will test much lower.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by flyweed
    I agree with Dave on checking for static on the TA test and then post back.
    Aerating does not bring down CH. Only water replacement reduces CH.
    The recommended level of CH for vinyl is 50 - 300, so you are fine with a CH of 180.
    Aeration raises your pH and your pH is perfect.
    You're done SLAMing when:
    Jan 2009
    Cupertino, CA
    1,966
    Hi, Dan,
    (Pssst, Dave, it's actually the R-0009 that has the static issue; R-0010 is the first part of the CH test.)
    --paulr
    BBB "Intermediate Swimmer"
    Aug 2009
    SW Wisconsin
    518
    Could anyone tell me what my shock level should be? currently my FC is sitting at 4.5....I want to go ahead and shock my pool and get it closed up for the season.
    Thanks
    Dan
    30,400
    It depends on your CYA level. YOu can find that relationship in Pool School in the FC/CYA chart.
    Aug 2009
    SW Wisconsin
    518
    My CYA is currently 40 ppm...so according to the chart I need to take it up to 16 ppm FC....so the pool calculator says this would be 611 oz of 6% bleach....I just want to be sure, I am using the calculator correctly.
    Dan
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Hi Dan
    If your pool is 27700 gallons it looks like you've got the numbers right. Happy shocking
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
