Results 1 to 7 of 7
Thread: How important is a pump pressure gauge
    TimS's Avatar
    Sep 2009
    Central Missouri
    214
    The gauge on my Sand Dollar doesn't rise above 18psi. The normal operating pressure on my clean filter (according to this obviously defective gauge) is 16psi, so at most my pressure gauge rises 2psi when the filter is dirty. I'm certain that the pressure does go above this, but the gauge is not registering it.
    The way the filter was installed, I can't see the gauge anyway without crawling under the deck. In order to correct this, I'd have to re-plumb the whole setup (PVC) to turn the filter head around, which I can do, but I don't know if it's worth the effort. Another option would be to re-plumb the gauge so that it is piped out around the side of the head instead of being directly mounted. (Note that I'm going to be doing a little bit of re-plumbing on this this winter to fix an issue with my backwash plumbing.)
    This summer, I based my filter cleaning on pressure at the return. When it felt like I'd had a significant drop in return pressure (and the current significantly decreased,) I knew it was time to clean the filter.
    Since I would have to re-plumb things, is it worthwhile to bother with a new gauge. Is it that important to know what the pressure really is?
    Is this a standard pressure gauge that I can get from someplace like Lowes? If not, any ideas where I'd find it? Specialty plumbing store?
    TIA
    24' AG Round (vinyl replaced 0909) - 13500 gal - Sand Dollar Filter (150lb) - Dynamo DYNII-N1-1 1HP - Hayward HP380 Heat Pump - TF-100.
    Central Missouri
    Before I speak, I have something important to say.
    Re: How important is a pump pressure gauge
    They're important. Neighbor's filter basically exploded, after realizing he had an obstruction. He had a non-op pressure gauge, never removed it when closing.
    They're generic. You can get them at Lowes or HD, for under 10 bucks.
    Kansas City, MO
    13500 gallon Foxx vinyl sport pool--inground (1988)
    Cristal-Flo sand filter
    Ray-Pak 406A digital
    1.5 HP single speed
    400 gallon Heldor inground spa, octagon
    Mar 2007
    Coastalish 'down easter'
    4,160
    You can certainly run a pool/ filter system without a working pressure gauge As you said, you just need to watch the return action to know when to clean the filter
    You seem to know your pool well enough to do this However, the gauge screws in so can be turned to allow you to see it
    Luv& Luk
    -Ted
    TimS's Avatar
    Sep 2009
    Central Missouri
    214
    Quote Originally Posted by waste
    It's not that it is upside down, it's that the head is installed so that the gauge is on the back side where I can't see it (or the sight glass either) without crawling under the deck.
    In order get it where I can see it, I'll have to put two elbows and about 3"-4" of pipe in the line. Not being a plumber, I don't know how much that would drop the pressure to the gauge, and if it would be significant. How accurate does the gauge need to be anyway? Any idea?
    It would be fairly easy to do, if it's worth the effort.
    Since I can't see the sight glass either, when I backwash, I just go to the end of the hose and watch that until it's clear. Less convenient than watching it through the sight glass, but it works.
    Central Missouri
    30,432
    The 90's will have virtually no effect on the efficiency of your system......I think the guage is very important.
    Each time my pump goes on, I check the psi for normal operation. It's a great indicator of anything not functioning properly or assurance that everything is.
    TimS's Avatar
    Sep 2009
    Central Missouri
    214
    Thanks. I picked up the parts last night (but naturally there are a couple that I missed so I have to go back again. [rant] Why on earth can't I ever get all the pieces I need on the FIRST trip? Even when I make a list! [/rant] Since it's pretty cheap and easy, (gauge was under $8, and pre-threaded brass fittings were under $8) I might as well fix it.
    Central Missouri
    Sep 2009
    Greentown, IN
    914
    Hubby and I just bought a used pool and needed to replace the pressure gauge. Thanks for making it easy to find our answers... he'll be making a run to Lowe's before next spring to fix it.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
