Results 1 to 14 of 14
Thread: In need of brush advice...
    Mar 2008
    Florida
    81
    well after 1 year of use the brush I had gotten with my pool has started to lose its bristles. Actually the bristles have become brittle and are snapping off making a mess of my sparkling clean pool :O Does anyone have advice on a good brush? Should they last longer than 1 year? Any makes to stay away from?
    thanks in advance
    12-15k gallons capacity, 18'x34'
    2 main drains 4 returns 1 vacuum line
    pentair intelliflo 4x160 pump 200 sq ft media filter full width (~7' wide) swimout at deep end
    pebble sheen white diamonds
    Guest
    Re: In need of brush advice...
    I like the stainless bristle ones. They last a lot longer, and should be no problem on a fully cured out pool (I see you are PebbleSheen). Doubt they'd be advisable on a liner pool!!
    Bruce
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hi Bruce - steel bristles are definitely! contraindicated for liner pools
    Lifeguard (Rainbow) products usually last a reasonable time
    Luv& Luk
    -Ted
    Mar 2008
    Florida
    81
    Quote Originally Posted by simicrintz
    Bruce
    wow, I would have never thought of that. I will look into that. I am assuming that the bristles are very thin to prevent scoring/abrading the surface to badly.
    Thanks
    Guest
    Quote Originally Posted by newfool
    Bruce
    Thanks
    Nothing to worry about. I have Blue Granite in mine, and I'm pretty familiar with the product (since I am the applicator in my area!). Mine's been down for almost eight years now, and it looks like the day it was done. I drain my pool every two years (hard water) and pressure wash it, then fill and start up again. Been using the stainless brush for at least 7 years on it. Don't lose any sleep over the stainless brush once you get it; you'll love it!
    Bruce
    Mar 2008
    Florida
    81
    Awesome Bruce! How hard is the water that you have to empty and refill? Mine runs between 225-300ppm. Just curious since we have the same finish. Has the brush lasted 7 years??! wow, what a value
    Thanks for all the info
    Guest
    Our water comes out of the tap at over 400 ppm I usually try and catch it before it hits 1,000 ppm or the calcium really starts to build on the tile, etc. I wish I could get mine down to the levels that you have (I should be able to make that happen soon; more to come....!).
    Probably gone through 2-3 brushes in that time frame. Brushes are cheap though! I don't sweat that too much
    Keep taking good care of that Pebble finish and it will take good care of you
    Bruce
    And, if you don't have one already, get a "Whale tail" for the brush as well. Makes brushing almost fun!
    16K gallon, Pebble tec, beach entry. Two 1 hp Pentair Whisperflos. One for Paramount MDX2 main drain, Paramount debris canister, and Pentair CCP 520 filter. One for skimmer w/sock and Paramount PCC2000 in floor cleaner. 3/4 hp Pentair Pinnacle for waterfall. Fiberstars fiber optic pool lighting. Aqua-Logic AQL-P-4 control panel with wired remote in the house. SWCG system that is not used. Ultra-Pure Ozonator that is not used.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by ntrsandman
    I've seen these. What is the advantage of having a whale tail?
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    May 2009
    Enterprise, AL
    54
    The wall whale pushes the brush head against the wall for you! The faster you push the brush toward the bottom, the harder it pushes the brush against the wall.
    20K gal IG vinyl 18'x36' rectangle, 2' radius corners
    Hayward Goldline Aqua Rite 40K SWG, Pentair Intelliflow VS 3050,
    Sta-Rite Cristal-Flo 24" Sand filter, Model T-240BP-1, Polaris 280 Auto Cleaner
    Sunstar solar panels (438 sq ft ), Pentair Sun Touch Controller automating solar panels, SWG, and Polaris
    TF-100 test kit
    polyvue's Avatar
    Aug 2009
    1,215
    Thank you, FSI_C-12IP & ntrsandman. I'm gonna hafta get me one of these.
    __
    Mar 2008
    Florida
    81
    I had heard of the whale tail and talked with a buddy that works at the pool store. He said that the whale tail was ok, but they were kinda cheap and tended to break near the top where the plastic was thin? I don't know if its true or not, but I ended up skipping on that purchase for now. Stainless steel brush for 3-4 years sounds like a winner to me! Bruce, I installed a water softner in my house before doing the pool, if I need to decrease the hardness of the water I just fill the pool with the softened water to help lower it
    Guest
    That should work, but watch the salt content of the water going in! Softened water usually contains high salt content, and that can be very corrosive to pool equipment
    Bruce
