Thread: Should I shock?
    May 2009
    Seminole, FL
    71
    Should I shock?
    I was on vacation for the past week or so and when I got back I noticed from green algae on my light and fixture. I put pucks in while I was gone and tested my FC about 2.0 when I got home. Probably a little low for my CYA of 45.
    I brushed off the algae.. I tested with my kit and got 3.5 FC, 0 CC.. (I added some chlorine) Should I still shock because I saw algae?
    ~13000 inground plaster
    150sq Ft Cartridge Filter
    22,543
    Re: Should I shock?
    Probably so, but do an overnite chlorine drop test to be sure. Here's how to do it. Pool School Overnite FC Test
    You'll need a FAS-DPD test to do it. Hopefully you have one of the recommended kits.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Should I shock?
    I agree, an overnight test to be sure
    make sure you are brushing those areas where you saw visible algae for the next several days, and it's a good idea to up your FC level a few ppm's and run the pump more often, you may be getting FC "dead spots".
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Should I shock?
    You have gotten good advice
    I, on the other hand, would shock my pool and not think twice about it
    Then, I'd do the Overnight Test.
    Sometimes I think it is easier to just shock it once, when you catch it early, rather than increase your FC level daily for a while. Your choice.
    Since we have been doing BBB, any shock we have done has been a one-time event.
    We rarely shock our pool. Maybe once or twice a year, and the twice would be "just because".
    You're done SLAMing when:
    May 2009
    Seminole, FL
    71
    Re: Should I shock?
    I brought my FC up to 15.5 last night, and it was 14 this morning. Still no CC though. I suspect the 1.5 drop was because I didn't test until 9am and there was some sun already hitting the pool. I'm guessing the overnight test has to be done early in the morning.
    30,408
    Re: Should I shock?
    While it's already been done (good work), I want to emphasize how much I agree with Butterfly......if you have visible algae in your pool, it needs to be shocked regardless of any test results.
