Results 1 to 9 of 9
Thread: polaris 280 wheels
    Mar 2009
    eastern washington state
    275
    polaris 280 wheels
    I have a Polaris 280 and it is one year old. the Axle plate that holds the wheel on broke the other day. So i fixed it with no problems. Well today we take the cover off and find out another wheel has broken off. was just wondering if this is common or Am i doing something wrong. It works great and can not live without it... makes life so easy... my concern is that when the tire falls off it leaves the axle sticking out, which could tear the liner. Has anyone else had problems with this?
    thanks
    live in eastern washington state
    18x36, Vinyl inground 24k
    Hayward 1 hp filter pump
    1 skimmer/2 returns
    24" sand filter, polaris 280 with booster pump.
    Aug 2009
    North Central Texas
    1,358
    Re: polaris 280 wheels
    Sorry about your problem.
    I've had at least three 280's since they were first introduced. The only reason I've had to purchase new ones is because my dogs have "rescued" them and then "killed" them. Expensive doggie toy.
    I've never had an axle break nor a wheel fall off. Mine get at around 10 hours a day use usually year round. My current one is over 5 years old. I've only replaced tires, hoses, wear rings and of course tail sponges which I now make myself.
    A good friend of mine has a 280 that is probably eight years old. It runs about 8 hours a day, year round. This has never happened to hers.
    My closest neighbor has one that is 3.5 years old. They have an auto cover so they don't run theirs as long as my friend and I but probably at least four hours a day year round. Mid summer they had to repair a broken part but not wheel or axle. They were so desperate not having the 280 run daily that they borrowed mine until the part came in (took 2 weeks because the pool store forgot to order it). They had so much stuff in the bottom that after a week without 280 no one in the family would get in the pool and it was in 100 F here.
    I wish I could help you but just wanted to let you know that your problem has not occurred with any of the hard working 280s I am familiar with.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Mar 2009
    275
    well maybe i just got one that was made on a friday or a monday....LOL Thanks so much fur the info....
    i will order a ner axle and get mine going again....
    thanks
    jim
    1 skimmer/2 returns
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by hayfarmer
    I have a Polaris 280 and it is one year old. the Axle plate that holds the wheel on broke the other day. So i fixed it with no problems. Well today we take the cover off and find out another wheel has broken off [...] Has anyone else had problems with this?
    thanks
    Yes, this happened to my Polaris 280. Since shipping costs are commonly higher than the parts, when something breaks, I have started ordering TWO of whatever the item is. I like the cleaner but it does seem they require attention several times a year.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Excessive, or high Cl level can make plastic brittle. This may or may not be your specific problem.
    Do you take the unit out while swimming and lay it out in the sun? This too can brittle-afy the plastic.
    Factory Warranty Station for:
    Oct 2011
    Frisco, TX
    47
    Old thread but mine just broke, 6 months old. I wonder if it is related to 5 months of the pool company telling me they were cleaning my pool but they weren't. Off balance chemicals?
    Size 13,000 gal | Filtration Jandy DE 60 | Sanitation PLC1400 SWG, Rainbow 320 | Placement in-ground (IG) | Coping Tennessee Crab Orchard
    Finish pebble smooth Tahoe Blue | Pumps Intelliflo VS+SVRS 3.0HP main | Lighting Jandy LED Spa/Pool
    Location Frisco TX US
    Hate to bring up an old thread, but I did want to emphasize the issue may be widespread. I have a 280 and within 2 months, the front drive wheel axle snapped. That wheel snapped three times over a years period. The fourth wheel just snapped, the non drive wheel, 2 months out of warranty. My chemicals are checked by the test kit, and the pool was never too acidic and never had too much chlorine. In fact, I used to have a 380 going with a very low pH in the pool that ruined the liner, but I never had a problem with the wheels snapping off.
    Now Polaris had sent me out a new wheel each time, but never addressed the underlying issue. Even out of warranty, they were very nice and given the trouble I have had, they once more took care of me. Each time I asked if this was a common problem, but they seemed not to answer the question directly.
    JPete
    Columbia, Missouri
    13600 gallons
    24' x 48" Round AGP. 1.5 hp/12 amp ecokleer pump. 22" ecokleer sand filter.
    rgrountree's Avatar
    Nov 2011
    Atascocita, Texas
    13
    I have a Polaris 280. In January one of the axles broke. I ordered the part and replaced. The following week a different axle broke, replaced this one and the remaining original axle. All new axles.
    Now April, I have another broken axle and a wheel at the bottom of pool.
    What could be causing this?
    Is it binding or some other issue? I have noticed the pool cleaner is not cleaning like it used to. It will not willingly go to the farthest reaches of the pool and seems to go in circles ending up near its connection point.
    Pool Chemicals are tested and good. Thanks in advance for any input!
    23,000 IG plaster pool, Jandy HP Plus 2HP (130 GPM), Jandy CV460 Cartridge filter, Polaris 280, Jandy LXi 400,000 BTU Heater, Jandy Watercolors LED lighting, 7' Raised SPA
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    I've had a 280 for 5 years. It runs 4 - 8 hours/day for 9 or 10 months per year. So far the only maintenance I've done is replace the float, replace the back-up valve, and put on a new set of tires. It stays in the pool except when someone is swimming. Never had a problem with axles, wheels, or gears.
    The 280 replaced a 180 that was 19 years old and had been rebuilt about 5 or 6 times. I finally got tired of messing with it and got the 280.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
