Thread: What is R-0013 in TF100 test kit?
    Sep 2009
    TN
    49
    While trying to get my new pool CYA up to spec, I have already used one bottle of R-0013 from my TF100 test kit. (A mistake on my first try didn't help.)
    Does anyone know what is the chemical in the bottle?
    My CYA is now up to 28, so I hope to only test once more before closing.
    new in 2009 - 18' x 36' IG vinyl liner, 23,300 gallons
    24" sand filter w/ 1.5hp pump
    Polaris 280 cleaner w/ booster pump
    30,403
    Re: What is R-0013 in TF100 test kit?
    It is essentially melamine but I wouldn't attempt a substitute......I doubt you'll get an accurate result.
    If you have one more bottle, that should be enough for 3 more tests and you really have no reason to test it 'til next Spring, IMO.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Absolutely right... but if lances4803 or someone else reading this post has reason to test often, refills are available:
    TF-100 Refills
    TF R-0013-2
    Cyanuric Acid Reagent (2) 2 oz bottles
    120ml / 4 oz $7.50 [$1.88 oz]
    Taylor CYA Refills
    Taylor R-0013A
    22ml / .75 oz $2.85 [$3.80 oz]
    Taylor R-0013C
    60ml / 2 oz $4.20 [$2.10 oz]
    Taylor R-0013E
    480ml / 16 oz $9.15 [57ยข oz]
    The 16 oz container can be used to refill smaller bottles and can be had for as low as $7.00 on other sites. Here, for example.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Sep 2009
    TN
    49
    I hoped Taylor had supplies, and that isn't a bad price for a refill.
    Hey, I'm just excited to get this pool going right!! (Of course, it was finished just in time for fall, and 9" of rain in the last week.)
