Thread: cloudy water
    Mar 2009
    Indianapolis, IN
    70
    cloudy water
    I opened the the pool today to cloudy water. Test results are PH 6.8, TA 110 and FC 0. Obviously I need to start shocking right away but have a question about the PH. I know that level is way too low, so do I add borax at the same time as bleach? If so does that need to be dissolved in water first? Basically I am unsure if I tackle both problems simultaneously.
    Thanks.
    18x36 ft
    19,000 gal IG vinyl
    Sand filter Tagelus 24"
    1HP Whisper Flo Pump
    Butterfly's Avatar
    South Carolina
    10,045
    Re: cloudy water
    Adjust your pH first and then shock.
    You're done SLAMing when:
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: cloudy water
    Raise the PH first, using borax to 7.4 then shock the pool. It's not uncommon if the pool was covered for a long period to see the PH drop down. Pre-dissolve the borax in a bucket of pool water and then pour in front of the return. Brush for a little while to distribute it.
    Retest the PH in about an hour and adjust if necessary. Wait until the PH is where you want to begin shocking, because FC levels above 10 will make the PH read a false high. Don't try to adjust PH if the FC is above 10 because the readings won't be accurate.
    Once the PH is where you want it you can begin to shock. Leave the pool uncovered while you are shocking.
    Mar 2009
    Indianapolis, IN
    70
    Re: cloudy water
    Ok, first dose of borax has been added. Now I need more help! I just checked CYA since I hadn't checked since the beginning of the season when it was 30. I am not sure where it is now because the black dot was very visible even when the water was filled to the top which is less than 30. Is this a problem? We will be closing the pool in the next month. Any advice on what to use for a shock level?
    Thanks again.
    18x36 ft
    19,000 gal IG vinyl
    Butterfly's Avatar
    South Carolina
    10,045
    Re: cloudy water
    I suggest you try a shock level of around 10 to 12 for now.
    Also, I suggest that you wait 'til spring opening to add your CYA, since you are about to close.
