Thread: Jandy valves
    Jandy valves
    I have Jandy valves how do I know which way is open?????
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: How to post a question
    Quote Originally Posted by calijack
    Recommend moving the last entry of this thread (September 22nd, 2009, 7:56 pm) to Getting Started or Pumping Station so that it is more visible to those with specific knowledge of Jandy valves.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Jandy valves
    Hi Calijack and welcome to the forum
    I moved your post to a more appropriate forum. Someone will be along soon to answer your question
    You're done SLAMing when:
    Guest
    Re: Jandy valves
    The handle of the valve points to the water flow direction. It should also have a "pie shaped" piece on the opposing end that says "close" (IIRC!) to let you know what end of the valve is in the off position.
    I can try and get a pic up if that helps later, or maybe post one of the valve you have so that we can see it and advise.
    Bruce
    Re: Jandy valves
    Bruce,
    A pic would be great. I have one at infow and 1 for vac and one for main drain. I finally found the word on there that says inlet. Why can't they just have open and close like those red ones..
    Quote Originally Posted by simicrintz
    Bruce
    Guest
    Re: Jandy valves
    Here's a pic of the JVA (automatic valve) instead of the manual valve, but the handle is the same for both. The handle is pointing to the right in the picture, which means that is the way the water is flowing. It says "off" on the opposite end, which means no water is flowing to the pipe to the right. (This valve is at the front of the circ pump, so technically no water is "flowing" through it as it is being sucked through the pipe as it enters the pump. Didn't want that to be confusing )
    I still get confused by these things, and I see them every day! You're right; you'd think they could make it easier!
    Hope the pic helps!
    Bruce
