Results 1 to 10 of 10
Thread: How fast will I blast thru the clorine
    rdkll's Avatar
    Jul 2007
    Huntsville, AL
    41
    with zero CYA....its gonna be a few days until I get the stabilizer...
    I bought bleace...but did I get enough??
    Thanks guys........
    1) The size of your pool in gallons = 33,500 16x32x40 L
    2) The type filter you have = 300lb Sand
    3) IG
    4) If it's IG, vinyl liner
    5) pump is 1.5hp
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: How fast will I blast thru the clorine
    Quote Originally Posted by rdkll
    You can never have enough bleace.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Jan 2009
    Cupertino, CA
    1,966
    I believe the half-life of FC in noonday sun with CYA 0 is around 35 minutes. That number sticks in my head, anyway, although chem geek does throw around a lot of numbers.
    That's full sun with no cover. Add your bleach in the evening and it should last all night, at least.
    --paulr
    BBB "Intermediate Swimmer"
    rdkll's Avatar
    Jul 2007
    Huntsville, AL
    41
    If I get home tonight and there is still clorine......is it safe to assume that there is some cya maybe. I know it held at 4ppm overnight.......does night time matter??
    3) IG
    5) pump is 1.5hp
    rdkll's Avatar
    Jul 2007
    Huntsville, AL
    41
    I got home at 6p and check the clorine........3.5 fc and .5 cc 4ppm TC. It held that all day........any thoughts?
    3) IG
    5) pump is 1.5hp
    Jan 2009
    Cupertino, CA
    1,966
    I think your CYA is not zero.
    --paulr
    rdkll's Avatar
    Jul 2007
    Huntsville, AL
    41
    OK, so is there any way to make the test kit cya test to a finer degree? It held 11ppm over night and will see what it does during the day today....supposed to be overcast and 80's
    3) IG
    5) pump is 1.5hp
    mas985's Avatar
    Pleasanton, CA
    11,741
    Is this because you can fill the site tube all the way and still see the dot?
    If so that just means you have less than 30 ppm and you should probably add some right away. Not much point in measuring it if it is that low.
    Mark
    rdkll's Avatar
    Jul 2007
    Huntsville, AL
    41
    I really appreciate the assistance on this.
    How do I add CYA so I dont overshoot............sounds reasonable....when you start to add it how long does it take to register....
    3) IG
    5) pump is 1.5hp
    polyvue's Avatar
    Aug 2009
    1,215
    If you have truly excellent circulation and water on the warm side, you can detect the increase in a few hours. But I've heard on this forum that it can take a week to fully register. You could try dividing the amount you want to add in two parts. Add 1 part now, wait 3 or 4 days, then add the 2nd part if needed.
    __
