Thread: High PH/low Alkalinity
    May 2008
    California City, CA
    51
    It seems like every time I empty, clean and refill my spa, it starts out great but no matter what I do I end up with really hight PH (about 8.0) and really low alkalinity (about 30). I am always confused as to what to do to remedy this problem.
    Templehb - 16,000 gal fiberglass inground pool, Aquapure 1400 SWG, DE filter.
    30,419
    Re: High PH/low Alkalinity
    Pool School has the answer. In "ABC's of Pool Water Chemistry"
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    You use acid to lower the PH and then Baking Soda to raise up the TA.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Be sure you keep your air lines closed when you're not using the tub.
