Results 1 to 18 of 18
Thread: Closing Question
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Closing Question
    This will be my first year closing a pool and i have read Pool School on it and dont find it too complicated. I will also be watching my friends dad close his pool in the next few weeks so i get a better understanding of it.
    But I had some questions that I couldn't seem to find answer too:
    Which plugs are better to use in the Return and or Skimmer lines for the winter time.
    Rubber
    Or PVC
    And how does one go about using the foam of a pool noodle in place of the "gizmo"?
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Closing Question
    I prefer threaded plugs whenever possible, but both work fine.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Gizzmos are for skimmers since they act as a plug and also take the squeeze from ice expansion.
    Although depending on how the pool is plumbed if there is a main drain it may be possible to have pressure on the gizzmo, and sometimes the gizzmo will leak. If a main drain is putting pressure on the skimmer during the closing I would recommend using the white plug (hayward sp-1022c) since it seals better than the gizzmo will.
    Rubber plugs can sometimes leak from their stems but depending on what you are plugging up a rubber plug might be the only option.
    I use all three of these products, but depending on the pool one is usually better suited than the other.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Mar 2007
    Coastalish 'down easter'
    4,160
    <deleted, cause I can't properly use a computer >
    Luv& Luk
    -Ted
    Mar 2007
    4,160
    If I may add a little to what Tim and Keven have said...
    When I see the white plugs (SP 1022 C) fail, it's because the o-ring has dry rotted, the liner wasn't fully cut out of the inlet/ outlet port, or the faceplate is cracked. A few wraps of Teflon tape will take care of this (though I prefer to fix the problem )
    For the Gizzmo, wrap the threads with Teflon tape and install it after you add some antifreeze to the line. (use a Gizzmo that sticks above the water level of your skimmer )
    I hope you have an easy closing and a good winter Info on closing can be found at Pool School
    Luv& Luk
    -Ted
    Cincinnati, OH
    424
    Great, thanks for the input on the plugs.
    I think i'll go with the screw on type with some teflon tape, since they just seem more secure.
    And since I don't have a main drain I won't need to worry about pressure on the gizzmo
    Eric
    Cincinnati, OH
    424
    Another question that i've been thinking about when closing an IG pool.
    Are you supposed to get your chemical levels correct before draining the water below the skimmer/returns.
    Or do you drain first then add your chemicals to get the correct levels?
    Eric
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Depends on if you have a way to circulate at the lower level, some pools don't in which case you treat, circulate the chems, then drain. Plus, can you accurately calculate dosing at the lower level for your chems?
    Cincinnati, OH
    424
    Quote Originally Posted by frustratedpoolmom
    That's what thought, since i dont have a main drain, i wasnt sure how the chemicals would get mixed around through the system.
    Thanks for the response poolmom.
    Eric
    Cincinnati, OH
    424
    Ok, so i'm bumping my thread with another question.
    I was looking at my filter system since i was going to blow the lines out with my shop vac.
    But the way my installer hooked everything up, he has all the PVC pipes that screw in all PVC cemented so there is no way to turn them to get remove the pieces to get them off.
    1) Does this mean i have to use the drain plug in the pump basket with a compressor to blow my lines out?
    2) Does this mean i have to leave my pump/filter outside all winter?
    Eric
    11,969
    Where are you located?
    Cincinnati, OH
    424
    I'm in southern Ohio, so we get fairly cold winters here.
    Quite often below freezing temps.
    I am thinking I have to cut all the PVC fittings off and attach Unions to it so I can remove/re-attach everything.
    Eric
    Mar 2007
    4,160
    You've got a VERY! good idea there, cutting the pipes and installing unions next spring
    The equipment will last longer if stored inside over the winter When you hose off the grids on your filter, don't put it back together - mice like to build their winter condos in the filters!
    If you need any help on the 'how to' on the plumbing, we'll tell you how to do it correctly
    Luv& Luk
    -Ted
    Cincinnati, OH
    424
    Quote Originally Posted by waste
    Yeah, I think i'm going to have to get a picture of my setup now, that way you guys can see how it is setup now.
    Then next spring before opening, i'll go ahead and redo some of them.
    As for the DE filter would it be alright to put that in a Rubbermaid container for the winter?
    I also read that you dont want to clean the filter with chemicals or acid until the opening, so that way the chemicles are not eating away at it over winter (is this true?)
    Eric
    Mar 2007
    4,160
    Quote Originally Posted by WestSidePool
    The chemical cleaning is probably better done as soon as you pull the gris=ds out, that way no 'junk' has coagulated on them
    Do the degreasing soak, rinse , and, only! if you have calcium in the water, the acid soak! Once the chemical soaking is complete, thoroughly rinse the grids and they are fine for the winter!
    You can store the equipment wherever you like, just don't set it up so that mice will find it inviting
    Luv& Luk
    -Ted
    Cincinnati, OH
    424
    I took a picture last night of my current set up, so hopefully you can give me some suggestions on what to change for next year.
    Eric
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Well you don't have a maindrain, so using a gizzmo should work just fine for you, and chances are I would use a sp1022c plug for your return lines assuming they will fit ( I can't see the pool). inspect your return line face plates, they have 4 screws to remove. remove the plate and look for stress cracks, if you see cracks replace the plate this will help ensure the plugs don't leak via a damaged faceplate.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Mar 2007
    4,160
    Good evening!
    Thanks for the pic!
    I would cut the pipe coming into the pump ~ 8" off the inlet. Then I'd cut the pipe coming out of the pump midwat on the horizontal pipe going into the 90 to the multiport. I'd also cut the waste/ backwash line midway between the multi and the 90. For the line feeding the CL 200 chlorinator, cut it where the new union won't be fouled by the suction line, the unions have a cuff that would be hard to tighten if there is a pipe next to it
    Remove the drain plug on the chlorinator, it's a 9/16" head (they should have used a SP 1500 UNPAK union to attach it ). Tape some plastic over the exposed pipes, so that water or critters don't get in, and bring in the pump and filter for the winter. Make sure that you have ~ no water in them, if you'll store them in an unheated area
    Always here to provide more help
    Luv& Luk
    -Ted
