Results 1 to 9 of 9
Thread: Trouble with repeatable DPD/FAS FC test
    Folks,
    I'm having problems getting accurate readings. Here is what I mean. I seem to be off by plus or minus 0.5 or so on a given reading. I did two tests this morning within 5 minutes with no equipment running and one was a FC reading of 4.5 and the other 5.0. As best I can tell, I did everything the same way. I notice that the meniscus on my "chlorine only" cylinder is a bit stronger than the other one for what it's worth, but I try and be careful.
    Is this normal for this test? Is there something I could do to make it more repeatable?
    -- jeff
    15,000 gal SWG pool, cartridge filter, all pentair equipment, variable speed pump, 400K BTU heater and spa, pebbletec finished
    30,432
    Re: Trouble with repeatable DPD/FAS FC test
    That's about as good as it gets and is perfectly adequate for most applications I can think of.
    If you require more accuracy, use a 25ml sample for an accuracy of .2ppm (+- .2)
    Why do you feel you need the additional accuaracy?
    May 2009
    Dallas, TX
    785
    The test is accurate to within +/- 1 drop, which is all the accuracy you'll ever need for your pool. For the 10ml sample that's +/- .5ppm, and for the 25ml sample it's +/- .2ppm.
    If you're asking because you want to verify that your procedure is accurate, then do several tests in quick succession from the same water sample. If your results are within +/- 1 drop you're good to go.
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by jeffbg
    Not sure why you took your samples with no equipment running (it's very likely, as Beez said, that you'll get better accuracy with just one sample.)
    Just the act of taking two samples from the same spot (one right after the other) may give you different results. I like to mix up the water via pumping for at least a few minutes and then take ONE sample from a point furthest from returns/water features. If you have a larger pool (30K+ gallons) consider taking two samples from opposite ends within a minute or two of each other, then check chlorine and pH (first) of both samples; you can average together the results.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Quote Originally Posted by polyvue
    The point of my "no equipment running" was to make the point that since I have a SWG, the variability in my readings was not due to the SWG running. The water features had run already this morning before my reading and had mixed up my spa and pool, so it had been "stirred" since sitting overnight. I try and take my samples away from the returns and the autofill, and approximately the same place every day to get consistency.
    Sounds like 0.5ppm is about as accurate as it gets, but makes me wonder if the overnight drop test could be a bit off since if you drop 0.5ppm and have an error of 0.5ppm, you could think you've lost 1ppm, and think you have an algae problem.
    -- Jeff
    May 2009
    Dallas, TX
    785
    As duraleigh suggested, use a 25ml sample for the overnight loss test for a +/- .2ppm resolution.
    Quote Originally Posted by Beez
    Procedure is the same -- same amount of the powder? One drop is then .2ppm rather than .5ppm?
    -- jeff
    May 2009
    Dallas, TX
    785
    -- jeff
    Use two scoops of powder, and yes, one drop is .2ppm
    Jan 2009
    Cupertino, CA
    1,966
    The last two lines of the Overnight FC Test Instructions specifically address this; overnight loss of up to 1.0ppm is okay.
    --paulr
    BBB "Intermediate Swimmer"
