Thread: Liquid Stabilizer - How Long to Retest?
    Sep 2009
    TN
    49
    I read in Pool School about the time interval before retesting after using solid stabilizer.
    How long is sufficient to wait to retest after adding liquid stabilizer (pump running 24hrs)? I would think 24hrs would be sufficient to thoroughly mix.
    new in 2009 - 18' x 36' IG vinyl liner, 23,300 gallons
    24" sand filter w/ 1.5hp pump
    Polaris 280 cleaner w/ booster pump
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Liquid Stabilizer - How Long to Retest?
    That would be extra safe. You could probably test after an hour. The liquid stabilizer dissolves in the water fairly readily so should register correctly on the test after it gets mixed by circulation. It's actually already somewhat dissolved in water as a slurry in the container.
    Sep 2009
    TN
    49
    Thanks very much!!
    Would have been nice to have the pool company know what they are doing and get me started right, but TFP seems to be doing it for me.
