Thread: Pool out of whack
    rdkll's Avatar
    Jul 2007
    Huntsville, AL
    41
    Pool out of whack
    OK, update on the war.....I can see a dime in the deep end (very clear)
    Latest numbers
    FC 7
    CC 1 (I have never had CC's before------although I saw one at the pool store The new VW CC
    Ph 8
    TA 120
    CYA 0 tested it last night 2X and once this morning
    I originally had a CYA of appx 90, turned over about 6700 gl for an estimated drop of 20 to 70. Pool store tested the cya and came back with 30. We have had a boatload of rain and I backwashed to waste enough to get the skimmers skimming again.
    What do I adjust first?
    Thanks in advance
    1) The size of your pool in gallons = 33,500 16x32x40 L
    2) The type filter you have = 300lb Sand
    3) IG
    4) If it's IG, vinyl liner
    5) pump is 1.5hp
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Pool out of whack
    Use some muriatic acid to drop the ph to 7.5 first, then add enough CYA to bring it to 40.
    Love TFP? Become a
    TFP Supporter!
