Thread: Borates
    Borates
    Is there any side affects to using borates in a forty year old pool with org. copper plumbing?
    doityourself..
    1997 gunite white plaster 24x36 double kidney shape pool with attached spa ~25,000 gallons.
    Hayward PRO DE, Sta-Rite 2 hp two speed pump, P4 and Goldline 40k salt system, G3 floor cleaner.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Borates
    Quote Originally Posted by BlueWaterPools
    Welcome to TFP, BlueWaterPools!
    I'm not qualifed to address your question, so I defer to those members using borates in older pools who are. Please check back again for a response. Thanks.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Borates
    I don't see why there would be any side effects.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Borates
    I don't see anything about negative reactions of borates with copper. Mostly copper will corrode from low pH and from very high oxidizer levels, especially in combination. Copper heat exchangers most commonly fail if they have tight U-bends as the rapid water flow turbulence accelerates the corrosion.
    If anything, the additional pH buffering from the borates should help maintain the pH which can only help reduce corrosion rates, though in practice borates are often used in pools using hypochlorite sources of chlorine or SWG systems where low pH is not very common -- such pools tend to rise in pH which is part of the reason borates are used in the first place.
    Re: Borates
    thank you for your replys...
    i have begun using borates and in my pools and the customers LOVE IT!!!!
    doityourself..
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Borates
    Glad it's working for your customers. Borates are a nice addition. They are not necessary and are optional, but they do have nice positive benefits. Just remember that if you have any customers with dogs that regularly drink from the pool, they should be taught not to do so. Drinking cups of water every day from the pool with 50 ppm Borates is getting close to the edge of first symptoms for male dogs. See this post for more details.
