Results 1 to 9 of 9
Thread: How do I vacuum to waste using a Cartridge Filter?
    I have a Hayward Xstream Cartridge Filter Model CC1000 with a separate pump. Is there a way I can vacuum to waste? I've been having a major algae problem due to neglect from the previous homeowners and everytime I vacuum, the filter spits this white residue back into the pool making the water extremely cloudy once again. I'm hoping if I can vacuum to waste, it will help solve that problem, but I have no idea how to do so with my filter.
    22,553
    Re: How do I vacuum to waste using a Cartridge Filter?
    There's no way to actually vacuum to waste with that filter. However, Hayward makes a SP0727 diverter valve for it that can be installed so that you can bypass the filter. It installs between the pump and filter.
    Here's a pic of it.
    Jul 2007
    Northern NJ
    299
    Found these 2 replies in another post. You could try one of these methods:
    frustratedpoolmom Post subject: Re: Another Baquacil conversionPosted: Thu Sep 10, 2009 8:07 am
    Location: SWSuburban Chicago, IL Report this postReply with quote
    I have a cart too. Couple weeks ago, after 8 years of pool ownership I "discovered" how I can vacume to waste. Sorta left me going "duh"...
    Anyway we had recently had heavy rains....the water in the pool had risen to the top rail. I wanted to drain the water out. I took the vacume hose and left one end on the grass. I took the other end and held it up to the return to "prime" it. The water flows out the hose and exits the pool - the syphon action continued the flow. I kept the hose end under the water, and attached it to my (manual) vacume head, then attached the pole and lowered it to the pool floor. By keeping the hose primed the water kept flowing. I vacumed the pool that way, and the water level lowered about 3 inches and I was able to do the whole pool!
    Anyway, I just thought I'd share my lightbulb moment....
    _________________
    Helpful links: Pool School; BBB for Beginners; The Pool Calculator; CYA/Chlorine Chart
    24' round AG pool, 52" high, Laars "lite 2" heater; Waterway 2 spd Pump;
    NO LONGER FRUSTRATED thanks to TFP.com
    Debstar60 Post subject: Re: Another Baquacil conversionPosted: Thu Sep 10, 2009 9:55 am
    Registered User
    Posts: 89 Report this postReply with quote
    I also have a cart. filter,what I did was take the hose loose where it attaches back to the pool after going through the filter (the eyeball).It still goes through the filter but not back into the pool. I vacuumed on low speed.
    Deb
    _________________
    27' 17,000 gal, cartridge filter, 2.5 HP Waterway 2 speed
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
    Does your cartridge filter have a plug in the bottom that you can remove?
    On mine, I remove the plug and turn off the return.
    The water comes from the pool and exits out the bottom of the filter. None goes back to the pool (or through the filter).
    It makes a mess around the filter pad, but it works.
    (you could probably hook a hose or something up to that filter drain, but I haven't tried it)
    In-Ground. White Marbelite plaster. 21'-7" x 38' Figure Eightish Custom diving pool with 9' deep end. 24,750 Gallons. Pentair Challenger 2 hp pump, Pentair Clean and Clear Plus CCP420 Cartridge Filter, Paramount PCC-2000 In Floor Cleaning system with Debris Canister. Pool/House was a foreclosure that sat dormant for at least 2 years, and was an actual swamp. Using BBB and POP I made it a sparkling backyard oasis. I have a TF100 kit, and I know how to use it (mostly!). This is my FIRST REAL pool, but thanks to TFP, I know what I'm doing! (mostly!).
    May 2011
    Montgomery, TX
    176
    i have a question about this. i have a cartridge filter and above the pump there is a regular spiget. could i hook up a waterhose to this and vacuum to waste like this? if this would work would i also have to turn off the returns to the pool? thanks.
    22,553
    The only issues with the spigot is that you'd have to figure out how to turn off the return(s) as you said, and it may be too small to allow for good vacuuming. Most of those faucets are severely restricted internally and would have a great deal of head loss and therefore the vacuum will be greatly reduced when trying to pump through it.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I actually figured out a way to vacuum to waste with a paper cartridge and it's cheap but it does take two people. Use either a funnel or a margarine container with a whole cut out of the side. Get a small vacuum hose and either put the hose in the funnel and put the funnel near the return IN the pool with the other end of the hose Out of the pool, so when you vacuum, the water will still come through the return, but be caught in the funnell, into the hose, and OUT over the side. Same theory with the container, you just have to put that over the return with the vacuum hose iin the hole, with the other end of the hose over the rim of the pool out on the grass. Same concept as backwashing but since you cannot do that with a paper cartridge, this does the trick for those small particles that come back into the pool when vacuuming.
    Jul 2014
    Ashland, OH
    2
    When I read this post, it changed my life. lol. I was able to this twice before and it worked beautifully. But last night I was unable to get the siphon action going. As long as I held the one end to the return, the water flowed out the other end onto the grass but as soon as I took it off the return (but still under water) the water would stop flowing. I don't know what I am doing wrong but I was frustrated to the point of tears. I'm probably missing something very simple but any advice anyone can offer would be appreciated.
    Tara
    ~10,400 Gal. (21' Round) AG Pool
    Cartridge Filter (90sq.ft.)
    Cheap 1HP Pump, One Speed
    Old Pool, New Owner
