Results 1 to 13 of 13
Thread: Electric bill through the roof!
    Mar 2009
    Woods of North Florida
    148
    I would like some help in trying to figure out just how much my pool pump is costing me to run. We have reduced our AC usage quite a bit (3 degrees higher during the day and 4 degrees higher at night) but our electric bill has gone up a lot! I need to get a grip on what costs what so I can figure out where the problem is.
    It is a 1 1/2 HP pump.
    The best I can understand our electric company charges $ 0.0999 per KWH, with a "wholesale power cost adjustment .017" (which I thought would be subtracted from the bill but is added instead).
    Please help me figure out the hourly rate to use my pump.
    Thanks!
    24' Seaspray Evolution CLX Above Ground Pool (~13600 gallons)
    Pentair Sand Dollar SD60 / 22.5" filter / Maximum Flow Rate 60 GPM
    Pentair Dynamo Pump 1 1/2 HP
    22,553
    Re: Electric bill through the roof!
    You have the same pump I have. It draws about 12 amps. At 120volts that's 1.56KW. At $.1169/KWH (.0999 + .017) you're spending $.1824/hour of run time. or 18.24¢ per hour.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Mar 2009
    148
    WOW! You're good! And fast! Thanks so much.
    Of course, now I don't know how to feel. I run it around 10 hours a day, so it's costing me around $60 per month. I wouldn't mind so much if we had been able to swim more, but the weather has been terrible the past two weeks.
    Thanks again!
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    How does this formula work? If I determine number of amps (from the motor) and voltage (via the power supply), how does one get to kilowatts? (1.56 KW for numberonenole's pump)
    As an aside, when I estimated the electrical bill two years ago for a new pool, I didn't consider the utility fees, state and local taxes and "green energy" fees that are added to each bill and based on usage. Worse, I forgot that in our area electric rates depend on a tier system... the first 1000 kw in a billing period (month) are ~.12 a kw, 1000-1300 are charged at ~.16, anything over 1300 kw is about 20 cents a kw! So, when I run my pumps in December & January (my highest energy months) or turn on my electric heater to warm the spa, lots of that energy falls into the highest tier. Big ouch!
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Jun 2007
    New Jersey
    653
    kW= (Volts x Amps)/1000
    kWh= Hours x kW
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    polyvue's Avatar
    Aug 2009
    1,215
    Quote Originally Posted by polyvue
    Quote Originally Posted by Durk
    kWh= Hours x kW
    I was able to calculate the approx. cost of my main TriStar pump. 3 hrs per day operation is costing me about $55.00 a month (summer rates, SMUD). That sounds about right. Thanks, Durk.
    __
    22,553
    Big ouch is right.
    On a three tier system it's very hard to figure out the usage unless you run the same things the same days each month. Normally I just figure 50-50. 50% at the low rate and 50% at the midde rate. 1300kwh is a lot of power. Not saying that you won't exceed it but if you do you got bigger issues than the pool pump. If you know you're going to get into the third tier you can curb your pump back a few hours to help.
    May 2009
    Dallas, TX
    785
    Really? 1300kwh is a lot of power? Many of us in the southern climes regularly breach 1300kwh during the summer. I'm surprised that running the air conditioner doesn't push you over 1300 during the summer months. I know it gets stifling hot & humid over there in S Alabama...
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    22,553
    Yeah, What the heck was I thinking. I must have been thinking 2300 because we regularly run over 2000 and have run as high as 2600!!! Glad we don't have a tier system!
    polyvue's Avatar
    Aug 2009
    1,215
    I already curb my pump back to ONE hour during the winter!
    Quote Originally Posted by Beez
    Here's the deal: California has much lower humidity in summer than the South East; still, many people use their air conditioners here during hot summer afternoons. I rarely do (personal preference--I use ceiling fans.)
    1300 kWh of electricity is not unusual during the winter for homes that are all-electric (as is mine; no natural gas or oil available where I live.)
    Greg
    __
    I comiserate - the top tier in the bay area is about $0.44/kwh... I'm ALWAYs well into the top tier, year around.
    - Jeff
    ~45Kg Pool with attached Spa, NSP-72 DE, Minmax 400 Heater, Tahoe Blue Pebbletech, Jandy SWG via Aqualink RS-8, The Pool Cleaner (black)
    Pumps: X3 Hybrid Pump (switches to SPA), 2HP Spa (additional, when SPA is on), and a 1HP For Waterfall
    8, 4x12 Solar Panels on the roof of the pool-house (~12' up)
    CAPTAIN JAMES T. KIRK: "I'M SORRY. I CAN'T HEAR YOU OVER THE SOUND OF HOW AWESOME I AM" (Thanks to TFP!)
    May 2009
    Dallas, TX
    785
    Quote Originally Posted by taekwondodo
    - Jeff
    GREAT GOOGLY MOOGLY! ...I was hating my $400/month electric bills this summer...don't know what I'd do with 'em year round...
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    Switching out our single-speed with a 2-speed cut our bill significantly. We were paying an extra $90/mo to run the pump 10/hr days on the single-speed. We went from an extra $90/mo to $30/mo and we run our 2-speed 24/7 on low.
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
