Thread: Light Green Colored Water
    Hello, I have a fiberglass in-ground pool with about 27000 gallons I would say in it, PH level is fine, Chlorine level is low and the pool looks a light green color. I use a Hayward Microclean DE 6000 Filter and run it from 930 am to 430 pm, and wake up the next day and I see the yellow algae built up on the stairs and sides of the pool. The filter runs between 20-30 psi [the arrow keeps changing throughout the cleaning up and down]. What would I need to bring the pool back to a more normal state?
    Also, I would like to buy a better test kit, anyone know of one?
    Lafayette LA, 30-35k gal, Sand Filter Tahitian HR25, IG, Gunite
    Jul 2009
    London and France
    Re: Light Green Colored Water
    Welcome to the forum,
    Your first step should be to read the Pool school (button top right) that will give you a greater understanding and there is a very good test kit available via the same link.
    Read the information on algae prevention and cure as a priority
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    Hello, Hallo! (couldn't resist) Welcome to TFP
    Recommend you punch up that big link the on upper right hand of this screen, modestly entitled "POOL SCHOOL." It will tell you much about what you need to know.
    Quote Originally Posted by hallo
    Many individuals on this forum use one of the test kits described here: Test Kits Compared. And there are many who are quite experienced in dealing with problems w/pool water, etc.
    Good luck.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Jan 2009
    Cupertino, CA
    Ditto to what polyvue said.
    Regarding the green tinge and the algae, that's almost certainly because your chlorine is low. Chlorine gets used up some every day, and more when you have a problem like algae. You need to keep on top of that, pretty much every day. When you have your new test kit and you can provide us with a full set of test results, we'll be able to give more specific advice.
    BBB "Intermediate Swimmer"
