Thread: Pool closed by pool store, unnecessary chemicals?
    So I have my pool closed the other day and noticed they added the following chem's:
    4 gallons of liquid chlorine
    1 qt of proguard algae 60
    1 proguard stain scale inhibitor
    I wasn't aware they were going to add these until after I was invoiced and I wasn't home when they did closed it. Lesson learned for next year, I am assuming that these chemicals are unnecessary as I have always maintained acceptable FC levels I just want to confirm.
    thx
    25000 G, Kidney Shaped, In Ground, Cement Pebbled Finish, Sand Filter
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Re: Pool closed by pool store, unnecessary chemicals?
    Do you know what strength liquid chlorine?
    I do add a bunch of LC when I close. Mine is probably 10%, I've never tested it. I add enough to get the FC to 20 at closing, a very heavy dose of chlorine for my pool. The "proguard algae 60' sounds like what we call polyquat 60 here. Some people use it, some don't. I do when I close but not a full quart. I don't know anything about stain guard inhibitors so I can't comment.
    I wouldn't sweat it this season. Probably the amount of LC added was a little high but that does depend on its concentration. Hang around and next year, do your own closing.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    30,432
    I don't think there's any harm at all. It does depend on the condition of your water prior to the additions.
    Can you post a full set of test results including CYA?
    Assuming you CYA was reasonable, the chlorine will be fine.
    I personally don't use an aglaecide but others do so no harm there.
    The anti-scale stuff is a chelating agent to keep metals suspended in your pool. Do you have metals? What is your pH?
    If you have no prior history of metals and/or high calcium then I suspect that was a waste.....However, it won't hurt anything except your wallet.
