Results 1 to 7 of 7
Thread: ich-40 power light red
    Have had ICH-40 SWG for 3 years and it has worked flawlessly. Today power light turned red, all other lights green. including cell life. It runs 6 hrs per day, 40% output. Manual says it needs to be serviced, but doesn't say what the problem could be. Any ideas? Thanks.
    Mary O'D
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: ich-40 power light red
    Is this the Pentair IntelliChlor Electronic Chlorine Generator IC-40?
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Yes -- It's the Pentair IC-40
    Mary O'D
    polyvue's Avatar
    Aug 2009
    1,215
    A few things come to fore from perusing the IC-40 User guide... some of them not too likely, however.
    Things to rule out:
    • a. very cold (50 degree F.) water
      b. a system controller glitch with the IC-40 or the Easy Touch contoller - try cycling the AC power to effect a reset of the system
      c. odd water chemistry (extremely high total dissolved solids, salt, metals, pH) - post water test results to get feedback on this
      d. blades need cleaning - inspect inside cell, clean w/muriatic acid solution per instructions
      e. malfunction in IC-40 cell or controller - you'll probably need Pentair support to diagnose
    Others on this forum may be able to offer advice based on experience with this model.
    __
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Please post a full set of test results, and how they were obtained (strips, kit, pool store).
    there might be a clue in the chemistry.
    Re: ich-40 power light red--Problem solved!
    Much to my amazement I was able to solve the problem (without a service call from my friendly pool guy). It's been raining a lot in South Florida and I add 40# of salt whenever the yellow light goes on. This morning SWG was flashing green indicating too high a level of salt so I added some water -- no change. I unplugged the unit from the power supply and removed the cell from the plumbing--the blades looked great. Reassembled and plugged in; Power light went back to green. The yellow salt level is on but pool tests real good for chlorine. I'll take water in to pool guy tomorrow and give the SWG 24 hours to decide if it's really low on salt again. Thanks to polyvue and frustratedpoolmom. I'm smiling!
    Mary O'D
    polyvue's Avatar
    Aug 2009
    1,215
    Quote Originally Posted by maryod
    Isn't it a great feeling when you do something simple and it actually works?!
    I'll take water in to pool guy tomorrow [...]
    You may wish to invest in a drop-type test kit so you can do your own testing. (See Test Kits Compared) You'll thank yourself in the long run.
    Welcome to TFP... hope to hear more from you!
    __
